A Bass VI for $200?
- Fiddy
Re: A Bass VI for $200?
Plot twist, its getting rerouted through Canada.
- MattK
NOOOOOOOOOOOOOOOOOOO
- MattK
I know this thread contains some of my all-time worst Photoshop work (I used to do it professionally, but that was with properly shot and lit images!) but I had to make a mockup to fill the waiting time.
- MattK
Well, the body's here, not quite as blue as I thought (altho it's seafoam, duh). I think this is gonna work pretty well, sitting the neck in the pocket at the point where the heel transitions to the rounded part puts the bridge at just the right spot on the body. Mustang trem and control plate, Jag switches, thinking maybe 2 pickups if this is a "student" model compared to the VI. Scale length is 30".
- MattK
Oh my god I've had the body for a year, that's insane. Well I got the bits out the other day and tried dry fitting it to work out the exact bridge placement, then figured I would need to drill neck holes so I'd better finish up the woodwork on the neck, then smoothed the headstock transition, remembered I wanted to put some veneers on the headstock, ordered some off eBay, discovered they were really thick, figured I would need a belt sander someday, waited for a cheap used one, then waited for belts to arrive etc. Anyway, today I got it going and I've sanded the headstock down, will smooth it out and glue the veneers, trim the veneers, shape the transition etc. Then I will try to get it up and running with just the bridge in place to see how it is as an instrument, then figure out where I want the pickups, what shape for the guard etc.
I mean, it's only been 13 years, I don't want to rush it.
- mackerelmint
Dude, how have I not seen this thread before now? This is awesome.
I love that this is a 13 year project, I feel so much better about all my project procrastination now.
- MattK
I estimate another 3-5 years before I get it mocked up, there's hope for us all.
(and thanks!)
(and thanks!)
- MattK
OK, it's time to do something. Realised I wouldn't be able to shape it accurately if I glued the front and back veneers at the same time. So I sanded the back smoother, applied Titebond Red and clamped, clamped, clamped until I was satisfied. It'll set up overnight and I'll evaluate tomorrow ...
- MattK
Glue had set, so time to trim it, drill the tuner holes and do the front. Trimmed it with a multitool which worked pretty well but occasionally tried to burn thru rather than cut. I'll shape the edges when both veneers are sorted out. Also realised a rebate was needed near the truss rod hole so the veneer glues flat.
And so, back to the clamps.
- mackerelmint
- MattK
Really, the all-time stupidest project. I even own a bloody VI now, I bought one in Shibuya about 7 years ago. Also it's so wet in Tasmania at the moment that I spend more time mopping water out of the workshop than doing project stuff.
- MattK
progress (slow but steady)
(tailpiece plate is just taped on in the right location, but the neck is drilled and attached now!)
- MattK
It's been a big day, I am SO EXCITED.
Tuner screws:
Marking out the tailpiece:
A few shallow holes for the hardtail screws and spring anchor points (no springs for now):
Tailpiece is ON and it's time for thimbles:
Thimble holes (freehand, YIKES):
Good thimble:
Very slightly tilted thimble:
WE HAVE BRIDGE:
(mounted backwards for more setback to intonate the lower strings)
MORE TO COME ...
Tuner screws:
Good thimble:
WE HAVE BRIDGE:
MORE TO COME ...
- MattK
Then it was time to break out the d'Addario Bass VI strings I bought 12 years ago (yes March 2010). Some minor issues stringing up, and that neck has not had strings on in 12 years, so it's all settling in. BUT THE MUSTANG VI EXISTS NOW. I got a chill when I had it set up and tried playing it. It's just plain great - the neck is narrow and round, the strings are tightly spaced like the original VIs, and it plays SO WELL. Still some buzzes and the bridge is cranked pretty high, so there's work to do, but it's everything I hoped for!
(Mustang Bass ferrules on the back! I guess a badge of honour.)
- sal paradise
I can’t describe how awesome this is.
It makes me want to invent a whole new genre of music playing in a weird tuning with loads of modulation & that new Boss slicer
