Talk to me about “burning tubes”
Make it loud here.
øøøøøøø
Re: Talk to me about “burning tubes”
Post by øøøøøøø » Wed May 05, 2021 5:14 pm
Blue fluorescence inside the tube isn't an indication of a problem; it's just a side-effect of electrons bombarding the glass envelope. You only really see it on output tubes (beam-forming tetrodes; pentodes, etc) but it's harmless.
You'll sometimes hear old-timers say that funny colors within the plate structure or down low within the tube can be the sign of a compromised vacuum, but that's not a manifestation of that problem I've ever encountered. In that case it wouldn't be long before the getter would turn from silver to white, anyway, and the tube would stop functioning
Scout
Post by Scout » Mon May 10, 2021 6:12 am
Thanks for that. I saw blue fluorescence in the lower section of one of the output tubes that was appearing in rhythm with the intermittent sounds that just started, I assumed it was a faulty tube and ordered a new matched pair. I have no experience with trouble shooting amps but being an electrician for my entire life gives me a background in diagnosing circuits and I may have to start with this amp. I have the original old school amp tech in my neighborhood that I usually take things to but I think I’m ready to dive in on this one .
øøøøøøø
Post by øøøøøøø » Mon May 10, 2021 11:42 am
Yeah, what you saw was certainly a sign of failure!
Most likely it was arcing across electrodes (rather than fluorescence)
johnnysomersett
Post by johnnysomersett » Mon May 10, 2021 1:01 pm
I used to kill a set of modern JJ's about once a year (well, one out of a matched pair) in my old OR120. If they didnt blow within 12 months, I'd change them anyway as part of the yearly service I did on it...just as a precaution. We played at almost full-volume every week at rehearsal, and gigs throughout the year, so they had a tough life. That amp was biased hot, CRANKED and then pushed with a boost/fuzz so I expected it.
Other than that I think I've had a couple of old ones fizzle out randomly over the last 25yrs of owning tube amps. Hardly anything to worry about really.
Unicorn Warrior
Post by Unicorn Warrior » Wed May 12, 2021 7:35 am
Can you still hear?
johnnysomersett
Post by johnnysomersett » Wed May 12, 2021 8:20 am
Can you still hear?
Pardon? hahaha
Jokes aside, I have actually got partial hearing loss these days. I had a test a couple of years back (I'm 39 fwiw) and I have significant loss in the 4-5kHz range. This means I have trouble hearing ringing phones, doorbells, women's voices (a blessing? :D ) and other things with the fundamental in that range. I've got used to it but it does mean I had to step back from what little sound-tech and recording engineer work I did - which kinda sucks.
jorri
Post by jorri » Fri May 14, 2021 2:02 pm
Is it really just 'modern tubes'?
Well, similar experiences, i used an ac30 in a LOUD band that probably didn't suit an ac30.
I replaced the tubes a few times until it actually was taken to a tech, who put in some NOS tubes and they never got changed again-which was his theory and it 'seemed' to work. I had Harma, EHX, JJ etc. before..
It was hardly every week, but actually during the time i wasn't in a band, basically as low volume as it could it also got through tubes.
Scout
Post by Scout » Sat May 15, 2021 7:50 am
Just found this on the local FB, seems to work but it will be my first tube related foray into the wide world of electronics repair.
Cool looking object!
DeathJag
Post by DeathJag » Sat May 15, 2021 10:10 am
COOOOOOOOL!
Unicorn Warrior
Post by Unicorn Warrior » Wed May 19, 2021 12:44 pm
Yes very cool. I saw one of these at a yard sale once. Not the same brand, but thought about grabbing it although I didn’t own a tube amp at the time
Scout
Post by Scout » Wed May 19, 2021 4:42 pm
I couldn't resist. It was cheap and close , it works and I have the room for it.
Back in the day any place that sold tubes had a self service tube tester, It doesn't
do everything but it will kick out a faulty tube.
