ShatoonBringerOfCorn wrote: ↑Tue Aug 11, 2020 10:19 amAnyone in the UK/Europe got a recommendation for where to buy a replacement pickguard? I want to swap the tort out for parchment or maybe white pearl
Squier Classic Vibe 70s Jaguar
- MayTheFuzzBeWithYou
Re: Squier Classic Vibe 70s Jaguar
Earlpilanz on ebay. From Glasgow.https://www.ebay.de/str/earlpilanz/ he seems to be away this week though - but back on Monday. Got all my replacement guards from him so far!
- CROSS_guitars
Wow!manwithtitties wrote: ↑Wed Aug 12, 2020 11:03 amIn regards to both questions: yes.CROSS_guitars wrote: ↑Tue Aug 11, 2020 7:26 pmThese look okay. did yours have the truss rod notch and the correct shaping under the upper control plate?
awesome!
- galvanism
Here's mine, had it since march. I've made a few modifications and done my best to set it up.
First thing I did was put strap locks in.
I taped the bridge posts as I'm not one for vibrato. The guitar has been brilliant for tuning stability, even in my freezing cold bedroom, so I'll keep it like this.
I also shimmed the neck so the bridge wouldn't sit so low when I set the action.
I'm using 11-48 (power slinky) strings. As a bit of a beginner, I do find them stiff at times but I'm toughing it out, though I'd be lying if I said I hadn't considered 10-46s.
I've put in a 3 way switch for the pickups and made the bridge pickup switch a kill switch. The strangle switch functions as normal.
I did quite like the tort guard but I felt like it made the surf green look a little too pale. The new pickguard is a parchment colour but it's quite subtle unless you have a white to compare it to. I think it's an improvement.
- mbe
@galvanism pickguard looks great and the fretBoard is a nice shade (darker).
- galvanism
- Backdrop
Haven't posted here since 2016.
- BoringPostcards
Welcome back!. Beautiful Jag.
- jdr1014
Great way to resume posting! Congrats and enjoy . That's a very pretty sunburst Jag......
- Backdrop
Thanks. One of the perks of Sweetwater letting you choose from the bunch. This one had the nicest burst and darkest neck compared to the others. Wasn't the lightest but being a bassplayer it didn't really matter.
- soul1
So it seems at some point Squier/Fender started using pickups with different specs in these. I believe for the first couple years, they were nearly identical to the Jag pickups in the VM models with the hotter bridge. I just measured the pickups in a late 2020 model and the neck pickup reads 6.12k and the bridge is 5.81k, so the bridge is much less than reported for the first version! Not sure if they changed suppliers or pickups due to the covid, or for some other reason.
Yes, the VM's "Duncan-Designed" pickups had a big diff in DCR between neck (~5.8k) and bridge (~11.4k).soul1 wrote: ↑Fri Jun 04, 2021 3:00 pmSo it seems at some point Squier/Fender started using pickups with different specs in these. I believe for the first couple years, they were nearly identical to the Jag pickups in the VM models with the hotter bridge. I just measured the pickups in a late 2020 model and the neck pickup reads 6.12k and the bridge is 5.81k, so the bridge is much less than reported for the first version! Not sure if they changed suppliers or pickups due to the covid, or for some other reason.
viewtopic.php?t=107830
Fender quotes +/- 10% DCR tolerance on their pickups, and so while the CV's are only "Fender-designed" (=> not Fender-made) it's possible that your 2020 CV pickups were designed to have nominally equal DCR.
Roswell (an arm of Korea's WSC Music) appear to be the pickup maker for the Classic Vibe Jazzmaster ....
viewtopic.php?f=6&t=112487&p=1563628&hi ... r#p1563628
... and it appears that they also did the (original) CV jag pickups ...
https://touch.adverts.ie/guitar-accesso ... p/21978160
Roswell list a neck jag pickup at 5.9k and jag bridge at 11.8k ...
https://roswellpickups.com/product/jg-adwh-n/
https://roswellpickups.com/product/jg-adwh-b/
https://shoppartsland.com/jg-n-adwh/
- mbe
Most likely Fender using up old stocks of VM Jag pickups on the new Classic Vibe Jags. On my CV Jag the label on the newer CV pickups reads "Bass VI/Jaguar" and measure 5.8 bridge and 6.2 neck. So I swapped mine over from bridge to neck and vice versa and I think it sounds better for balance.soul1 wrote: ↑Fri Jun 04, 2021 3:00 pmSo it seems at some point Squier/Fender started using pickups with different specs in these. I believe for the first couple years, they were nearly identical to the Jag pickups in the VM models with the hotter bridge. I just measured the pickups in a late 2020 model and the neck pickup reads 6.12k and the bridge is 5.81k, so the bridge is much less than reported for the first version! Not sure if they changed suppliers or pickups due to the covid, or for some other reason.
- sciuri
Just got a shell pink one and setting it up! I switched to a mint pickguard but would like to get more aged white or cream pickup covers to match it better. The stock ones are noticeably whiter than my other Fender "aged white" plastics.
Does anyone know the pole spacing on the pickups (51.5mm or 52mm)? My measurement tools and eyes are not precise enough to make out a 0.5mm difference, and the Fender USA Jaguar pickup covers (005-4492-049) are 51.5mm per a vendor.
Or if you know of other brands that are known fits, please let me know! Thanks!
EDIT: The Fender USA Jaguar pickup covers 005-4492-049 do indeed fit my Squier CV 70s Jaguar. I didn't find exact measurements for the pickup covers, but I did find out Bare Knuckle uses these covers for the Marr pickups, the pole spacing of which is 52.2mm.
- sciuri
Opinions between the stock pickup covers versus more aged looking ones from Fender?
Stock Squier:
Fender aged white:
Stock Squier:
Fender aged white:
- Amon 7.L
Normally I would prefer the stock ones but the aged ones look like like a better match to the colour of the binding.
