SuperAxe
Post by SuperAxe » Fri Mar 08, 2024 12:41 am
MattK wrote:
Wed Mar 06, 2024 4:35 pm
viz Image
Nice, that is an SA-5 carcass. SA-50 pickups won't fit.
I saw one on Yahoo Japan. Did you get that one?
MattK
Post by MattK » Fri Mar 08, 2024 5:06 am
Yeah, that’s the one. It was listed as a 50 but I see what you mean about the pickups. I think the ones I have are the right size but I haven’t tried yet.
(edit) I just went and had a look and yeah, the smaller pickups for sure. However the headstock logo is a bit different from other SA-5s (taller font, pearloid inlay) and it doesn't have binding on the neck heel or the inside angle of the horns, which I understood to be a SA-5 identifier. Weird one! Maybe it's a SA-30? Serial number is 8240 which is 1968 I believe.
tr@shM4gik
Post by tr@shM4gik » Fri Mar 08, 2024 9:30 pm
Body/Pickguard/Plates by @Deed_Poll. (modified version of his Marauder kit)
Finish by @copacetic.
Just waiting on pickups and the bridge.
ludobag1
Post by ludobag1 » Sun Mar 24, 2024 10:40 am
changing string on this beast
byby tort
hello leopard ,vinyl stycker on old guard
and i thinking of gluing false fur on the guard like my strap cover
invisible man
Post by invisible man » Wed Mar 27, 2024 5:31 am
https://soundcloud.com/billy-gashade
seenoevil II
Post by seenoevil II » Mon Apr 01, 2024 6:02 pm
Here's my 1979 Guild D25. It had a pickguard crack and the OG guard was curling up pretty bad. So, time to pull it up and replace it after gluing and cleating the crack...except. Whatever glue guild were using tore up the spruce top pretty bad. I heated things up as much as I was comfortable and did my best to work in line with the grain, but almost half the thickness was lost in places. :fp: bummer.
So, I sealed it with shellac, made an ok color match (it was better before the top coat), then evened out the topography with CA.
The OG guard was very dark tort, almost black, and it's pretty large, so supplies are a little tough. I made up this one, but I think it's a little corny. I have another one on the way that should be darker.
hulakatt
Post by hulakatt » Tue Apr 02, 2024 12:01 pm
I've seen that one Guid acoustics were the pickguard came off on it's own too?
She/Her
kifla
Post by kifla » Tue Apr 02, 2024 9:18 pm
Left hand XII
JSett
Post by JSett » Wed Apr 03, 2024 11:48 am
My 65 VibroChamp.
It's been getting darker and darker over the last 2 years to the point where it was really starting to sound dull.
I pulled the 250pf cap out the tone circuit to see how much it had drifted - but it hadn't. Reads 262pF which is probably about as good as it was when it went in. The two 100k resistors pulling away from it were also <10% out (so, in spec).
Confused, I turned to the pot itself. Well well well... 156k in circuit, 171k out of circuit. So about 30% drift in the wrong direction. Cleaning it didn't help at all so I just dug out a modern 250k CTS and measured that. 272k out, 249k in.
MUCH BETTER!
Yay for science. And teaching yourself how to fix your own amps (with a little help from friends) :-*
JSett
Post by JSett » Thu Apr 04, 2024 8:05 am
Quick edit on previous posts success story. Turns out I put the wrong taper pot in :fp: didn't even check. What a numpty. Correct taper arriving tomorrow to correct silly boy mistake.
JVG
Post by JVG » Thu Apr 04, 2024 1:58 pm
Left hand XII
Love this - thanks for looking after us lefties!
Shadoweclipse13
Post by Shadoweclipse13 » Fri Apr 05, 2024 3:08 am
Left hand XII
Seconded! It's looking great so far! Side note: I would seriously love access to a pin router :-*
ludobag1
Post by ludobag1 » Fri Apr 05, 2024 11:59 am
Done :)
bodhi
Post by bodhi » Sat Apr 06, 2024 2:25 am
Done :)
... really really need to start a cover band called Deaf Leopard by now ;D Looks fun!
Amon 7.L
Post by Amon 7.L » Sat Apr 06, 2024 6:35 am
Done :)
Indeed, bodhi!
Deaf Leopard and the Cheetara-master!
Cool job, Ludo!
