The Unofficial OSG 60s Yamaha SG Thread
MattK
Re: The Unofficial OSG 60s Yamaha SG Thread
Post by MattK » Fri Aug 23, 2019 7:44 pm
Pretty good! I have one switch to repair and then I might see if I can demo it.
windmill
Post by windmill » Sat Aug 24, 2019 4:26 pm
Excellent
that looks good.
Mechanical Birds
Post by Mechanical Birds » Mon Aug 26, 2019 3:43 am
I need one of these so bad. Sleeping on that one on the guitar center site for $400 will haunt me till my dying day.
MattK
Post by MattK » Mon Aug 26, 2019 8:25 pm
and they were only made for 2 years! The thing that really gets me is that if you want to date it by the serial number, all the Yamaha electrics made in 1966 (SG-2, SG-3, SG-5, SG-7, SG-12) have a serial number in the range 0398-3951. Meaning they made 3500 of them in total - 500 - 800 of each, for that year? Same for 1967 (serials 3952-7433). So at the outermost stretch there might be 2000 SG-3s ever made.
Weldingfellow
Post by Weldingfellow » Fri Jan 22, 2021 2:40 pm
Hello everyone.
I see I’m pretty late to the thread here but thought I’d give it a try anyway.
I’ve inherited a 1967 Yamaha SG-3.
I’d like to sell it. I’d like to see it played or even loved.
Thought I would see if there is any interest. If so I can provide lots of pictures and answer any questions.
Bear in mind that I’m new to guitar so my knowledge is developing...
Not sure how to provide pictures here though...
Thanks
Chris.
SuperAxe
Post by SuperAxe » Fri Jan 22, 2021 7:28 pm
Hello everyone.
Thanks
Chris.
Hiya, pics are always welcome. Just load them on your favorite image site and then link them in your post with the 'image button'. What country are you in?
PorkyPrimeCut
Post by PorkyPrimeCut » Fri Jan 22, 2021 11:32 pm
But also, bear in mind that trading (or discussing a possible trade) outside the "For Sale" section is prohibited.
joeSG100
Post by joeSG100 » Sat Jan 23, 2021 1:23 pm
Hello everyone.
Thanks
Chris.
would love to see photos
Odjuret
Post by Odjuret » Sat Aug 21, 2021 6:51 am
Hi,
This thread is pure gold! :)
I got my 1966 SG3 the other day. Have really wanted one for a long while and got it for a OK price. A case was included and if not a SG3 case, I think it´s from the period.
I bought it at a auction site and I did not realize the knobs were wrong, it has Jaguar style knobs. The string guide nut is a plastic one (I think they should be made out of metal), one tuning peg post has been replaced and the switch to the upper controls has broken off. The upper control also does not work. There is no vibrato arm, but I will purchase a new one.
The tuning heads, pick up pole screws, bridge and vibrato has rust of various degree. Is it OK to clean them up and if so how?
There are some work to be done on this one, but I had to put strings on it and it works (with the lower controls engaged anyways). :)
Here are som pics of it. I will take photos with the pickguard off as well and post.
https://ibb.co/pjpG7ZC
https://ibb.co/4tx36y2
https://ibb.co/M70fwVf
https://ibb.co/frt1nZr
https://ibb.co/BzZMm9X
Yamaha SG-3 #1284
Yamaha SG-3 #1537
will
Post by will » Sat Aug 21, 2021 8:43 pm
That case looks original to me - it should have a sort of hole inside for the strap button on the upper side to fit into.
There is someone in Japan that makes replacement tremolo arms that fit quite well:
https://buyee.jp/item/yahoo/auction/x1000032236
The knobs will be tough to find since they were only used on early Yamaha electrics, so ebay or Reverb could be helpful there.
Here's a pair on Reverb. ...for $180!
https://reverb.com/item/36116232-yamaha ... -rare-sb-2
Tuners sometimes show up too - maybe these have the correct posts? I can't tell from their photos.
https://reverb.com/item/41023399-yamaha ... ers-1970-s
Odjuret
Post by Odjuret » Sun Aug 22, 2021 8:32 am
Hi Will!
Thanks for your reply!
I bought a tremolo arm from that seller yesterday, but I might have bought one that doesn´t fit... It was a SG2 arm, but I assumed they are the same for both SG2 and SG3. Well, it will show once I get it. :)
Whoa, that is a couple of expensive knobs... I think I will look around and see if I can get someone to do some 3D-modeling and print a pair. If that won´t cost too much.
Does anyone have a electronic schematic to share? Did not find one in the previous posts.
I know nothing about guitar electronics and wonder if it would be possible in any way to wire following pick up configurations:
Bridge
Bridge + middle
Middle + neck
Bridge + neck
Neck
Thanks!
Yamaha SG-3 #1284
Yamaha SG-3 #1537
SuperAxe
Post by SuperAxe » Wed Nov 03, 2021 11:30 pm
Well, Took me a few hours to re-read this whole thread again... Pity that quite a few photo links no longer work. Still, some good info here that will come in very handy :whistle:
SuperAxe
Post by SuperAxe » Fri Nov 12, 2021 10:46 pm
Nothing in this thread talks about the manufacturing dates stamped in the whammy bar cavity, so for completeness I am adding that...
In the thread "Yamaha SG-3 tear-down and restoration" on page 4, I found one of the remaining photos not having been obliterated. This one shows a white SG-3 with a date in the whammy bar assembly pocket as well as one in the neck pocket. The one in the latter looks hand written.
The photo is low res, so I have played around with contrast and brightness to bring out the numbers as clear as possible. I believe it shows: 7.41.21;
** Edit - found another photo of the neck which also shows the stamped date but this time very clearly; So it actually is 7.41.27 **
This means that the Showa date format is 'month.showa emperor year.day' so this date conforms to 21 July 1966. This stamp confirms my earlier assumption about the date in my SG-2 which shows 12.41.5. (Once I have removed the neck from my SG-2 I will update if it also shows a date in the neck pocket).
Here the photos:
July 27, 1966
December 5, 1966:
balston11
Post by balston11 » Sat Dec 11, 2021 2:47 am
Hello all first post I was directed to this forum by "Superaxe" I have a website for Yamaha Fender and Burns Guitars with a small section on English Westones home page is
www.alston-family.co.uk
I have added some pages on Early SGs and there is quite a bit of info missing. If anyone can add, correct any information or has any comments please let me know at the very least I think some of you will find this interesting SGs start here
https://www.alston-family.co.uk/SG/sgsurf.php
Bill
ludobag1
Post by ludobag1 » Sat Dec 11, 2021 4:39 am
Interesting the story of 2 magnets of bridge pickups and the plate
First time i read this
