Is a 22 watt tube amp suitable for home use?
- BarnyardCoral
Re: Is a 22 watt tube amp suitable for home use?
FWIW, I use a 24w Supro Saturn as a "bedroom amp" and I use an AIAB for my low volume OD tones. My current AIAB is a Catalinbread Formula 5F6. I've found it to have the most natural, amp-like sounds out of the various ones I've tried. So yeah, a 22w tube amp can work fine.
And I will be the one to hold Larry Csonka down, kiss him so hard, I'll take Larry Csonka's breath away...
*Scheckenbacker on TGP
- s_mcsleazy
i'm using a traynor guitar mate reverb as my home amp AND..... yeah. it's not overwhelmingly loud, but it's barely running past 2 on volume. still, not like i was going to be able to use my normal rig in the flat...... hell, i carried it up the stairs once and decided "never again"
I got the 20ish watt Swart AST that now lives at my practice space in May 2020, so it spent some time at home while things were locked down.
Obviously no meaningful overdriven amp sounds were possible at home volumes. I found that a Klone (Archer Ikon) was super helpful in bringing this amp to life at low levels though, and I’m pretty sure it would do the same for others.
- Larsongs
I’m rediscovering an old Fender Champion 110 Amp I bought back in the late 80’s or early 90’s if I recall. I haven’t played this thing in years…..
Last night I was up late & didn’t want to make a lot of noise so I plugged it in, grabbed a Tele, some Headphones & played it for a while..
It has a Clean Channel & a Drive Channel. EQ has Bass, Mid & Treble. Has Inputs for Headphone, included Foot switch & one for External Spkr. It’s a bit smaller than my Fender 65 PRRI..
I’m not a big fan of Digital Amps but was able to dial in pretty good Cleans & Drive & was surprised as to why I haven’t been using it for my late night playing all along?
I don’t know if there are any of these little Amps out there any more but thought I’d mention it…..
- noisepunk
someone with a better understanding of circuitry will hopefully chime in, but functionally, in my experience attenuators make the amp sound like a lower wattage version of itself (complete with lower breakup point) whereas a master volume knob, past a point, will sound like the amp is a bit starved of energy, if that makes any sense... i imagine what i'm hearing equates to a difference in how the highs and/or lows are rolled off.HedonismBot wrote: ↑Sun Oct 17, 2021 2:24 pmAlso, what are the pros and cons of the attenuator switch vs master volume control?
P.S: it’s been a while so thanks for bearing with my possibly dumb questions.
yum–i'd love to get my hands on one of those.garyfanclub wrote: ↑Mon Oct 18, 2021 1:36 pmI run a 18W Ampeg Reverborocket in my apartment, works fine and sounds good - I play fairly clean though, I *do* use an Echoplex preamp to fatten thing up a bit but other than that, no complaints from the neighbors or from me tone-wise.
That said it's *definitely* overkill... requisite pron
- MayTheFuzzBeWithYou
Hehe, that‘s my kind of taste.
Dripedge Bandmaster (40W) with a 2x15 Bassman cab in the living room. Would probably be enough to raise the attention of the whole neighbourhood - but on about 3-4 it‘s loud enough to feel and sound really good.
I‘d recommend getting an amp that you really like AND feature either a master volume or an effect-loop (best one with adjustable volume) my Supersonic 60 was always too loud and THIS + an AY7 instead an AX7 made it tame-able).
I also tried the tube amp doctor silencer before but it took so much of the dynamics. Can‘t say much about inbuilt attenuators or those half-power switches though. Orange has these often, right? And so does the new Tone Master series Deluxe Reverb. Maybe this would be a good starting point.
- Larsongs
Well, I played it today without headphones at normal volume.. Now, I remember why I haven’t played it in years! Shrill, harsh, annoying Digital sound!Larsongs wrote: ↑Sun Oct 24, 2021 7:54 amI’m rediscovering an old Fender Champion 110 Amp I bought back in the late 80’s or early 90’s if I recall. I haven’t played this thing in years…..
A friend of mine got a 5 Watt Blackstar Tube Amp.. I think someone here has one too.. I think they sound great for Rockin’ at low volume!
- sookwinder
Just commenting on master volume control.
There are a number of circuit designs that can be used to achieve a master volume functionality…IMO some good some crap. The type I have used in my designs successfully is the Post Phase Inverter Master Volume PPIMV
Overdrive and distortion can occur both in the amp circuitry and the speakers. Obviously we are just talking about it occurring in the circuitry as the volume when using a master volume dimed down would not cause any speaker related distortion to occur
If the master volume is located after the phase inverter and before the power valves the sound produced at low master volume levels should and will have any overdrive produced by the preamp circuitry. It will not have and overdrive or distortion that could be produced by the power valves being run at their limit… ie at “11”
I can achieve awesome creamy (BF circuit) or aggressive Neil young style sound (tweed circuit) with the master volume set way down, as the preamp is still running as per normal and with the preamp volume control set high normal overdrive will occur in the 12AX7 or 12AY7 preamp valves
In fact when I record with the amps I have built with PPIMV I normally never have the master volume at 10
I will set up the sound I want via the preamp sound and the raise the over all volume to a level where the speaker is chugging away quite nicely
The fundemtal question I have is do people really want to achieve loud overdrive sounds and low room volumes?
The human ear hears sound differently depending upon the level of the sound. So what you set up at high volume levels probably won’t sound good at low room levels or at least it will sound different
I used to run one of my amps that I built with a MV in my lounge room…. these days I just use a Vibro Champ
Just easier to use and if I want some FX just plug them in before the VC
- Larsongs
I seldom, if ever run anything, 10… My AC15 & AC10 can have Master Volume at low levels & then dial in the Top Boost to taste..sookwinder wrote: ↑Mon Oct 25, 2021 6:33 amJust commenting on master volume control.
Works ideal for Low, Medium & Loud Volumes…
- HNB
Not tube, but my new number 1 amp. Totally loud enough for my living room and even likely to practice with a band. (Could be mic'ed on stage and it also has a preamp out to go into a power amp or something similar.)
It is AMAZING. The clean and dirty channel is awesome. Three band EQ. The chorus isn't really useable for me (just has speed control), but everything else is 10/10. I like having it at 4. Beautiful cleans and you don't have to worry about running it louder to get the tubes working.
IMG_20211029_195811 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- hulakatt
If you're driving an amp into OD than a Champ is loud. If you're looking for lush cleans, a Twin Reverb is great. If you're jacking straight in, turn up the amp and turn your guitar's Vol knob down for even better cleans.
She/Her
- hulakatt
I use a BF Bassman or jtm45 a lot around the house so...
She/Her
