Lowe Guitars shop notes
BTL
Re: Lowe Guitars shop notes
Post by BTL » Fri Jul 02, 2021 1:11 pm
Alright, alright, alright.
After much cajoling, I decided to take a crack at editing in Photoshop. I used the Quick Selection tool to create a vector mask and the Curvature Pen tool to refine the mask. The background color is a very light gray (e1e1e1), something I could not have done using my previous mask in GIMP.
I may go back and try this in GIMP to see how much more difficult it is, but it was awfully easy in Photoshop once I got the feel for it.
Owner, Lowe Custom Guitars
BTL
Post by BTL » Fri Jul 02, 2021 7:45 pm
Round 2 was much easier.
BTL
Post by BTL » Fri Jul 09, 2021 7:18 pm
The 32" medium scale conversion necks have been my most successful venture. I'm going to try to build on that over the next few months.
BTL
Post by BTL » Sun Aug 15, 2021 10:03 am
The workbenches and shelves I built back in 2011 served their purpose for a decade. The tall shelves are at my brother's place along with the largest remaining woodworking tools and all milling, shaping, and finishing is done off-site. My current home workshop/office is where I accomplish all assembly and minor fabrication tasks. Understanding that, I broke down one of the work tables to serve as a bench for the ROSS and the plastic tables serve as general workbenches for sawing and routing when as the need arises. In many ways, I'm back where I started, but a whole lot wiser for the experience.
BTL
Post by BTL » Mon Aug 16, 2021 8:47 am
Lindy Fralin builds two 5-string pickups for me under a P90 cover with no holes. The first is his Big Single, a sidewinder design that uses a magnet on top of a mild steel blade. The magnet used in the pickup is a bit of a trade secret and it's not what is shown in the photo.
In order to accommodate a 5-string bass, I had to have wider blades cut from mild steel. I also need to cut and glue together guitar bobbins. I made up a cutting jig and use a blade wrapped in packing tape as a gluing jig. These are ready for winding and Lindy's shop will take it from here.
BTL
Post by BTL » Mon Aug 16, 2021 6:46 pm
My second Fralin 5-string option is a Split-J 3+2 under a P90 cover with no holes. I cut down, shape and narrow standard bobbins and use a scrap dogear P90 plate for fitment. I'm a sucker for noise canceling so I have both of these Fralin sets wired up with braided leads. I also offer a Lollar Thunderbird V and I haven't seen anybody else offer them yet.
countertext
Post by countertext » Mon Aug 16, 2021 7:18 pm
You crazy! Post finished pics ASAP!
BTL
Post by BTL » Mon Aug 16, 2021 7:41 pm
They've been out there for quite a while and the 4-string looks identical. This is just a peek under the hood.
BTL
Post by BTL » Tue Dec 21, 2021 2:59 pm
Between the pandemic, building a house in 2020, building a pool in 2021, and supply chain challenges, my builds have been at a standstill for a while. That's all about to change. I'm off work between now and January 3 and I have a pretty good backlog of inventory...the wheels are in motion! Here's the first update, installing machines and fitting the neck on a Chromasonic V that's been in the pipeline for longer than I care to admit.
BTL
Post by BTL » Tue Dec 21, 2021 7:04 pm
Due to backlogs and capacity challenges in their core business, my current OEM is no longer able to supply me with custom hardware. Also, I'm seeing a LOT of builders on Instagram using hexagonal pickup rings, so...new it's time for a new OEM and an updated perimeter shape. The new outline is backwards compatible with my current rings & rout and refines the design in a way that covers the rout in a simpler, less obtrusive, and (I think) more appealing manner.
The new designs are laser cut from mild steel by Send Cut Send, the mounting holes are countersunk on my drill press, then they're shipped off to Advanced Plating in Nashville to be plated in shiny chrome. The updated control plate is configured so a Switchcraft toggle can be mounted on one end or in the middle. A #7 O-ring will perfectly center a CTS pot in the oversized hole for V/V/T applications.
Shadoweclipse13
Post by Shadoweclipse13 » Wed Dec 22, 2021 3:57 am
Ooh yeah, I like the new ring shape!!!
BTL
Post by BTL » Wed Dec 22, 2021 1:26 pm
Thanks! I'm happy to say that seems to be the consensus.
BTL
Post by BTL » Thu Dec 23, 2021 8:01 pm
I like to think of these as GT40 colors, but I think they're actually Porsche Gulf Livery. Tis enough, twill serve.
Shadoweclipse13
Post by Shadoweclipse13 » Fri Dec 24, 2021 6:38 am
That is sweet!!!!
BTL
Post by BTL » Tue Dec 28, 2021 12:31 pm
Thanks, I'm pretty excited about that build!
Not much excitement here, just a reminder that all of my necks are assembled using EZ Lok carbon steel inserts and 8-32 machine screws.
