Cross Guitars - projects and restorations
CROSS_guitars
Re: Cross Guitars - projects and restorations
Post by CROSS_guitars » Sun Jul 17, 2022 3:13 pm
solfege wrote:
Sun Jul 17, 2022 9:36 am
That is beautiful. How does it balance / sit in one's lap? I'm just imagining it as a perfect couch guitar.
Ha, funny you should ask. I only bothered to test that out last night and the guitar balances perfectly on my lap.
The body actually has a bit of weight to it and it sits on my knee right where the switch and neck pickup is.
Tele295
Post by Tele295 » Mon Jul 18, 2022 7:12 pm
CROSS_guitars wrote:
Fri Jul 15, 2022 10:18 pm
Quick mockup.
I ended up going with the trapezoid Dano XII bridge.
Very nice. What’s the scale length?
Jill Martini & The Shrunken Heads - all aloha, all the time
CROSS_guitars
Post by CROSS_guitars » Mon Jul 18, 2022 10:20 pm
Cheers!
It is 24" scale.
It will be interesting to see how well it plays. I have never played a short scaled 12 string.
Nudger
Post by Nudger » Tue Jul 19, 2022 12:18 am
Cheers!
It is 24" scale.
This is trailblazing.. Im hoping it inspires a glut of jag scale/type 12s for those who dont get on with 25.5
sal paradise
Post by sal paradise » Tue Jul 19, 2022 1:35 am
Cheers!
It is 24" scale.
Mustang XII :? :? :-* :-*
ThePearDream
Post by ThePearDream » Tue Jul 19, 2022 8:04 am
Looks great with the Dano bridge!
I fully expect the shorter scale to be an improvement. I had already decided that if I ever build another XII, it is going to be a short scale, so I look forward to reading what you think about it.
Doug
@dpcannafax
CROSS_guitars
Post by CROSS_guitars » Tue Jul 19, 2022 3:13 pm
I have to admit, this guitar was originally intended to be a 6 string with a Duo-sonic/toronado bridge but the design was screaming for it to be a 12 string. Plus I have a thousand guitars and I don't own a 12 string yet.
The short scale decision was an aesthetic choice but I reckon it will play well as a 12 string. The strings will be slightly looser, like they are with a 24" scale. Less tension on the neck too.
solfege
Post by solfege » Wed Jul 20, 2022 5:40 pm
Oh man, this gives me so many ideas. I'm going to be super interested in what you think of the jag pickups with the 12 too. I just happen to have a set of those lying around...
JVG
Post by JVG » Wed Jul 20, 2022 6:43 pm
That 12-string looks like the result of an affair between a Fender XII and Brian May’s Red Special. That’s gotta be a good thing, in my books.
CROSS_guitars
Post by CROSS_guitars » Thu Aug 04, 2022 8:18 pm
I finally bought a fretboard radius jig.
I could have made one but decided to buy one. But I made the sled, at least.
It's set up for vintage 7 1/4" radius.
It worked pretty well. Very accurate. Although next time, I won't glue the binding on first as it chipped off and I had to redo it, which was a huge pain.
CROSS_guitars
Post by CROSS_guitars » Thu Aug 04, 2022 8:22 pm
And a couple of days later!
Test assembly.
I can't do much more to it for now because the weather here is crap.
In the meantime, I can file the nut etc, and string it up.
copacetic
Post by copacetic » Fri Aug 05, 2022 12:12 pm
Test assembly.
Turned out absolutely gorgeous! I want one of my own 8)
Owner/Operator - Feelgood Guitars
CROSS_guitars
Post by CROSS_guitars » Fri Aug 05, 2022 5:58 pm
Thanks! Well, you get first dibs.
I strung it up for a test run. Glad I don't make harps. What a pain in the arse!
So far so good. I like to try the neck out before I do any fret leveling. And also, I don't like going crazy on
filing the frets down. It shortens their life span. So I only do what's necessary.
The neck pickup is omitted so I can access the truss rod. And I'm still waiting on the 3D-printed XII string tree.
Lieutenant030
Post by Lieutenant030 » Sat Aug 06, 2022 4:37 am
That's sooooo good! I think it's gonna be a proper janglemonster
Lieutenant030
Post by Lieutenant030 » Sat Aug 06, 2022 8:18 am
That's sooooo good, think it's gonna be a proper janglemonster!
