By the way, which attenuator circuit are you using for the small amps, or is it a VVR? I have some projects going on which I'm thinking of integrating some way of getting decent sounds out of at a low volume...Dr Tony Balls wrote: ↑Thu Mar 17, 2022 8:33 amAll this is reminding me that awhile ago I set out to create a true bedroom amp. Something push-pull and made with pentodes that sounded like the big boys, but at like half a watt. I didnt fully succeed. I started with attempting to use EF86s as power tubes, and it worked but really didnt sound great. Then after enough thinking and researching I decided to try the concept with ECL84s. They dont make them anymore but NOS they're cheap as chips. Each one has a pentode and half a triode as well, meaning that with a pair of them you could use the triodes for LTPI phase inversion. I alredy had a phase inverter wired up so i'm not using the triodes, but in the future I would. Anyway....blackface-ish circuit at ~2 watts and it sounds awesome. A little loud for bedroom, still, but attenuator or MV brings it into check rather nicely.
- bodhi
- Dr Tony Balls
The one in that was just a 5W 25Ω pot acting as a volume control on the OT secondary. The amp is so small that you can get away with easy stuff like that. However, if I was doing it over again i'd just use a LarMar type MV.bodhi wrote: ↑Thu Apr 21, 2022 7:10 amBy the way, which attenuator circuit are you using for the small amps, or is it a VVR? I have some projects going on which I'm thinking of integrating some way of getting decent sounds out of at a low volume...Dr Tony Balls wrote: ↑Thu Mar 17, 2022 8:33 amAll this is reminding me that awhile ago I set out to create a true bedroom amp. Something push-pull and made with pentodes that sounded like the big boys, but at like half a watt. I didnt fully succeed. I started with attempting to use EF86s as power tubes, and it worked but really didnt sound great. Then after enough thinking and researching I decided to try the concept with ECL84s. They dont make them anymore but NOS they're cheap as chips. Each one has a pentode and half a triode as well, meaning that with a pair of them you could use the triodes for LTPI phase inversion. I alredy had a phase inverter wired up so i'm not using the triodes, but in the future I would. Anyway....blackface-ish circuit at ~2 watts and it sounds awesome. A little loud for bedroom, still, but attenuator or MV brings it into check rather nicely.
Instagram: thetonyballs
- bodhi
Ok, thanks for the info! I'll see what I need to sort out for amps in different sizes...Dr Tony Balls wrote: ↑Thu Apr 21, 2022 7:47 amThe one in that was just a 5W 25Ω pot acting as a volume control on the OT secondary. The amp is so small that you can get away with easy stuff like that. However, if I was doing it over again i'd just use a LarMar type MV.bodhi wrote: ↑Thu Apr 21, 2022 7:10 amBy the way, which attenuator circuit are you using for the small amps, or is it a VVR? I have some projects going on which I'm thinking of integrating some way of getting decent sounds out of at a low volume...Dr Tony Balls wrote: ↑Thu Mar 17, 2022 8:33 amAll this is reminding me that awhile ago I set out to create a true bedroom amp. Something push-pull and made with pentodes that sounded like the big boys, but at like half a watt. I didnt fully succeed. I started with attempting to use EF86s as power tubes, and it worked but really didnt sound great. Then after enough thinking and researching I decided to try the concept with ECL84s. They dont make them anymore but NOS they're cheap as chips. Each one has a pentode and half a triode as well, meaning that with a pair of them you could use the triodes for LTPI phase inversion. I alredy had a phase inverter wired up so i'm not using the triodes, but in the future I would. Anyway....blackface-ish circuit at ~2 watts and it sounds awesome. A little loud for bedroom, still, but attenuator or MV brings it into check rather nicely.
- UC3
Just after first coat of Z-poxy.
Meant to be a Mustang/Tele mashup with maple neck and Charlie Christian's.
I see plenty of sanding in my future...
- daCod
My very first guitar lives again. 97 Cyclone bought brand spanking new by yours truly from the long gone Scotty’s Guitars in Norfolk NE. Ordered the fender pearloid guard from Mars Music (oh man those were the days) in the sprawling metropolis of Omaha my senior year of HS. Good times. Simpler times.
Now sporting a Novak WR in the bridge and 80’s Schaller Germany Telecaster bridge pickup (adaptor plate made from a scrap of tort) in the neck. No real clue how it actually sounds as kiddos are sleeping so we’ll have to wait until tomorrow for loud time.
I’m giddy. Feel like a damn kid again. 🤩🤩🤩
your paranoia must be weapons-grade.
“I have terrible hearing trouble. I have unwittingly helped to invent and refine a type of music that makes its principal proponents deaf.” ~ PT
- s_mcsleazy
do you mind if i sent this to my bandmate? i have a feeling they'd love itdaCod wrote: ↑Tue Apr 26, 2022 7:55 pmMy very first guitar lives again. 97 Cyclone bought brand spanking new by yours truly from the long gone Scotty’s Guitars in Norfolk NE. Ordered the fender pearloid guard from Mars Music (oh man those were the days) in the sprawling metropolis of Omaha my senior year of HS. Good times. Simpler times.
- daCod
But of course- Do it!s_mcsleazy wrote: ↑Wed Apr 27, 2022 1:32 amdo you mind if i sent this to my bandmate? i have a feeling they'd love it
- Dr Tony Balls
- hulakatt
- Dr Tony Balls
Well, there was a full, working, Hot Rod Deluxe circuit in there that the owner asked me to gut and replace with a different one. So that. It's gonna be a 30W version of the BF-15 circuit I often make. Sounds more like what the guy wants and will be a ton more reliable.
- ThePearDream
A white Limba body.
Testing the fit on a control cavity shield plate that I had laser cut from 1mm aluminum.
Doug
@dpcannafax
@dpcannafax
- hexes
*looks over to 24yr old HRD in the corner that's never needed more than tubes and shrugs*
- Lieutenant030
I've been working on this recently, which incidentally led me to OSG. I'm humbly in the presence of some very talented craftspeople, but taking it all in.
This was a Guitarbuild Mustang blank in Poplar. Just the neck pocket was routed out.
What I did was rout out two large chambers from the back, then glued on a 4mm Poplar ply backing piece which was then bound.
Neck is an Epihone, so 24.75" scale, built up with a Chigsby and Jag-style bridge.
The scratchplate is 3mm trans blue perspex, rescued from work. I've glittered the reverse of it, but I'm not totally sold on it so far.
So this is where we are at the moment. I can see this being something that gets stripped and rebuilt/reconfigured fairly regularly.
- hexes
I just love that Tony's post was a completely gutted HRD.johnnysomersett wrote: ↑Mon May 02, 2022 11:16 am*looks over to 24yr old HRD in the corner that's never needed more than tubes and shrugs*
There was a great video sometime in the past few years about the switch to ROHS with the same design. The old HRDs were 'fine', hot bias not withstanding. Once they moved to ROHS and started saving a couple dollars per amp, the issue with the solder joints cracking around the power tubes really skyrocketed. The only HRD failures I've seen working with backline companies have been 'newer' ones. My buddy has a couple, has toured with them forever, and has had great luck, but his are definitely old.
They're just an amp that gets piles of abuse. The price was right forever for what amounted to a great amp. The old blues deluxe in the oversized cabinet is fantastic.
