Poly. To sand or not
- scotty66
So I'm almost at the point of applying the poly to my Jagmaster project. Do I really need to sand it in between coats or just apply what I'm happy with and buff it after it's dry ?
Now and then I'll try to bend
- JazzBlaster
Re: Poly. To sand or not
Polly is easy, I'd sand before you paint and when you're done. As long as you have no mess ups you should be fine.
- k o y l
I'm not so sure of that... ...JazzBlaster wrote: Polly is easy
