In a word: yes. Your neck needs to rest in the bottom of the pocket, or you're going to have intonation issues. Also make sure that once you dowel and re-drill the neck holes that the 12th fret is 12.75 inches from the saddles (all strats are 25.5 inch scale). You shouldn't have any fit issues, as all strats are (or "should be") made to the same specs...kle wrote: After thinking a little bit, i think that the screw holes in my neck could be wrong.
$trat build (IMG heavy!) and full of lazyness...
- missionguitars
Re: $trat build (IMG heavy!) - PLEASE HELP!
MissionGuitars.com
"Like" me at https://www.facebook.com/missionguitars
- Stereordinary
Fixed.missionguitars wrote:Also make sure that once you dowel and re-drill the neck holes that the 12th fret is 12.75 inches from the saddles in their forward-most position (all strats are 25.5 inch scale).
- kle
Ok, looks like i've got issues
Gonna get some good wood glue tomorrow. Toothpicks: check!
- kle
So, i didn't drill it until now.
a) i'm being totally lazy right now
b) our drill is shit
c) i haven't got the wood glue i was talking about
But there's progress on the pickguard!
The guy who soldered it for me already got & finished it, i just have to transfer the money to get it.
Good news, after the long wait for Rockinger to send it.
- jaguuuar
can you explain this to me?kle wrote: ...read about Fenders with misaligned necks and how a quick, strong push in the right direction can solve the problem.
- kle
Re: $trat build (IMG heavy!) and full of lazyness...
If the neck is a little askew, you give it a push in the right direction so that it's straight again.
- the older brother
jaguuuar wrote:can you explain this to me?kle wrote: ...read about Fenders with misaligned necks and how a quick, strong push in the right direction can solve the problem.
Service bulletin #6 at your service:kle wrote: If the neck is a little askew, you give it a push in the right direction so that it's straight again.
- kle
Thanks, Jerker!
You really are a "freak" for Fenders
- Haddock
If it doesn't work, Pete T. from England had found another method. Applies even to glued necks.
“Man does not cease to play because he grows old; man grows old because he ceases to play.” -- George Bernard Shaw
- garyptaszek
I know how he feels... i fooking hate Les Pauls!Haddock wrote: If it doesn't work, Pete T. from England had found another method. Applies even to glued necks.
Dont know why he's still playing them though
Custodian of the Buickmaster
- Max
I think he just has bad taste in guitars.. He plays Strats nowgaryptaszek wrote:I know how he feels... i fooking hate Les Pauls!Haddock wrote: If it doesn't work, Pete T. from England had found another method. Applies even to glued necks.
- Slow-Pop
Max wrote:I think he just has bad taste in guitars.. He plays Strats nowgaryptaszek wrote:I know how he feels... i fooking hate Les Pauls!Haddock wrote: If it doesn't work, Pete T. from England had found another method. Applies even to glued necks.
Except for his P90 SG!
Before bringing up drugs with your kids, hook your turntables up to a wah-wah pedal.
- kle
Thanks guys.
Would be cool if you wouldn't always quote that pic, if you have to talk nonesense round here.
Here's the guard, not ready, from Friday. It should be finished now and has plastic parts in off-white on it (ignore the yellowed bridge pickup).
- Slow-Pop
Sorry
