This is how it came to me.
20230107_174838 by Hentai No Baka, on FlickrArtemis P1 / Case Study #5 / "Half Pear"
This body has extra contouring to make an angled neck heel that is of such marginal benefit, that I won't be doing it again for these designs. Two piece alder body, rough sanded to 120 grit, few dings NO FINISH. Black acrylic pickguard hand rubbed to a dull satin, featuring a watercolor style sticker of a halved pear. Custom aluminum control and pickup/bridge plates. CV50s Tele neck and bridge pickups, purchased years apart from each other. 4-way lever switch with black strat switch tip. Master Volume and Tone controls with barrel knobs. No shielding, still fairly quiet. Stainless steel pickguard and control plate screws. Squire CV Jag/Jazz bridge that would benefit from some Loctite. Unbranded vibrato with lock button. Vibrato arm with black tip. Some weird strap buttons I had in my parts box. Custom stainless steel neck plate. Starcaster by Fender neck with Arrow headstock that had some lifting frets, I re-pressed every fret and did a full level, crown and polish, stock tuners, stock nut, but I adjusted the slots and removed extra material, but didn't polish it since it's plastic. Maple shaft has a decent flame to it, rosewood board is pale brown. Neck plays well, narrow nut and medium C, satiny finish with a few dings. 11-48 strings. Weighs 7lb 12.5 oz.
20230107_174859 by Hentai No Baka, on Flickr
Things I notice about his work. The parts are precise. The pickguard and plates fit together very evenly. All lines are consistent. The gap around the bridge plate is the same size all the way around. The bridge thimble holes are centered in the plate. The pickguard follows the body shape perfectly. I appreciate the blade switch being parallel to the body edge. I also like the offset third lower screw hole on the control plate.
20230107_193638 by Hentai No Baka, on Flickr
20230107_193642 by Hentai No Baka, on Flickr
20230107_193647 by Hentai No Baka, on Flickr
All the holes for the pickguard, plates, and such are well placed and well supported with body wood. (None of that "hole too close to the edge" thing.)
20230107_194456 by Hentai No Baka, on Flickr
20230107_194459 by Hentai No Baka, on Flickr
The neck pocked rout is clean and both the stock neck and my new neck I am working on fit it well.
20230107_194558 by Hentai No Baka, on Flickr
I love that his tremolo rout has the corners done so I don't have to chisel them like with most Jazzy bodies I get.
20230107_194509 by Hentai No Baka, on Flickr
