Single coil size humbuckers or something else in CV jag
- Ceepers
Hey all
Lurk here a lot but rarely post…….
After some ideas / experiences. I’ve just swooped on a bargain CV jag on eBay. Been GASing after a black jag for ages.
I already have a VM jag with the fender 65 pups in so I have classic jag covered.
I’ve also got a couple of jazzmasters , one of which has p90s in it as well as a gretsch with filtertrons and a epiphone es335 with PAf style humbuckers in
I play in a covers band and generally play one of my offsets. I don’t really want to duplicate what I have already and I can see an attraction band wise to having something with a bridge humbucker / darker rockier sound but a janglier single coil neck pup ( I think changing / playing multiple guitars a lot a small pub gig is a bit too “precious” ) so……
Are the CV pups different enough to the AV65 to keep them in?
Anyone have any experience with single coil sized humbuckers or would I just wish I’d done the routing for a full size?
Is there something that sounds ( ish )like a filtertron in a single coil size - I like the brightness of the gretsch vs the darker paf style buckers but it feeds back way to hard to gig much!
Your learned opinions please!
- sal paradise
Re: Single coil size humbuckers or something else in CV jag
I’ve used hot rails in a strat & a couple of different hot wound singles in a Tele. All sounded great.
- JackFawkes
In general I've always found DiMarzio's single coil-sized rail humbuckers to sound good, and there's a pretty broad spectrum of them to choose from to possibly fit the voicing you're going for.
Maybe a Chopper paired with either a Fast Track or an Air Norton S, depending on which direction you want to go?
Jack
Jack
- NICQ
I have a Bullet Mustang with single coil sized Dimarzio Hot Rails :
Cruiser Neck (Neck) and SuperDistortion S (Bridge)
Very good combo - the Cruiser is very crispy and bright and the Super Distortion heavy in the mids
The Chopper is also a good choice for the bridge and the Fast Track 1 sounds good as a balanced neck pickup
Their website is very accurate with the output und EQ values of each pickup
- camilonava27
I second this, rails are the way to go!JackFawkes wrote: ↑Fri Jun 24, 2022 9:27 amIn general I've always found DiMarzio's single coil-sized rail humbuckers to sound good, and there's a pretty broad spectrum of them to choose from to possibly fit the voicing you're going for.
Jack
- tammyw
I tried a Chopper/Cruiser combo in a Mustang, and something else they recommended after that, but I didn't like any of the lower output ones, they just seemed too thin and lacking character. The only one I really liked was the Super Distortion S, and maybe the Pro Tracks were borderline acceptable.
But I'd seriously consider routing and going with full size pickups you really want.
- 1452L
Are the DiMarzio rails pickups just a straight drop into a Jag?
- tammyw
I think DiMarzio makes them both with and without the traditional Strat style flange, so you would want the no-flange style. Still, with the shielded cable coming out of the middle of the pickup, it's a tight squeeze to get it into a Jaguar rout. The last time I tried to fit some into a Jaguar, I stripped off the outer sheath completely. Also, I vaguely recall that they're rather tall pickups, which might be a problem on some guitars. You'll need some different mounting screws, too.
- 1452L
Thanks, sounds like a PITA to be honest!
