Dirt cheap Jaguar kit
- Stepney
Currently resisting the temptation the pull the trigger on this:
https://m.aliexpress.com/item/400012662 ... t=Pc2Msite
Has anyone got any experience of these?
Alongside the caveats of ordering off Aliexpress, I’m fully expecting the pickups and pots to be rubbish, but if the body, neck, routing, scale length and frets are decent it could be a pretty economical starting point for a project.
- Nudger
Re: Dirt cheap Jaguar kit
Bought an offset type off aliexpress a fiew years ago.
The control plates were made of mirrored plastic
Not same guitar as this but I would check with the seller.
- Stepney
Ha ha, fake metal.
As cheap as it is, I’m kind of hoping someone has already given it a go and can give some sort of reassurance, particularly as you’re not far off a second hand Squier at that price that you could mod.
- bodhi
Personally I'd just give it a pass... Dunno about your local market, but herewards I saw a decent used Squier for 280€, which is about a sneeze from what that Aliexpress kit comes down to including import taxes.
Nevermind it being a known commodity, already finished and probably a lot better quality parts as well.
- Stepney
Yeah, I agree. Really reinforces just how excellent value the recent Squiers are I guess.bodhi wrote: ↑Tue May 24, 2022 1:49 amPersonally I'd just give it a pass... Dunno about your local market, but herewards I saw a decent used Squier for 280€, which is about a sneeze from what that Aliexpress kit comes down to including import taxes.
I just noticed this - seems like the same kit - there appears to e a lip on the neck so I'm definitely staying away:
https://pangomusic.en.made-in-china.com ... -728-.html
- LVC
Yup, confirmed from te pics on the AliExpress page posted above
Also: Strat pickups, switches instead of rollers on the upper control plate
Create art, not content
- iainmayfield
you pay for what you get - it looks total rubbish!!
better to by a cheap Squier and upgrade it surely!
- Unicorn Warrior
Oddly enough, I kindof want that mirror plastic. I’m eventually on a quest to make a light Jaguar and those would help a ton
- JackFawkes
It's probably just "mirror" acrylic, like WD Pickguard's color option #10.
Jack
Jack
- LVC
Thin aluminum plates would be a good compromiseUnicorn Warrior wrote: ↑Tue May 24, 2022 10:22 amOddly enough, I kindof want that mirror plastic. I’m eventually on a quest to make a light Jaguar and those would help a ton
Looks like trash to me.
You can buy a Harley Benton MS-60 for less too.
- Fiddy
Hot garbage
- ohm-men
Stay away from these as far as you can. Sorry, but these are utter garbage... there is no other way to describe this attrocity.
Really, get a hold of used Squier Jaguar... You'll thank me later for that....
The one I once held wasn't even 24" scale to begin with.
