Where to get string-through like on this Kauer guitar?
- scheissami
Anyone know where to purchase this? Does Kauer make their own? Much nicer than the ones I found on StewMac and other sites on the interwebs, also looks easier to flush mount...
Cheers!
https://www.dropbox.com/s/tsul97o8s0h5e ... .jpeg?dl=0
Cheers!
- Stereordinary
Re: Where to get string-through like on this Kauer guitar?
Hipshot makes them.
- scheissami
I can’t find them on their website… Maybe I’m just being obtuse?
- Gordon
- Gordon
- Gordon
Less identical but very cool, from forumite Cross Guitars: https://www.shapeways.com/product/3UXQM ... rule-plate
- jvin248
Do you 'need' string-through?
I find changing strings on a string-through model is like flopping a dead fish back and forth. I much prefer top-loading bridges.
String-through string changes are a good way to start off that Relic paint chipping exercise
If you cannot find that part ... you can make a plate or block with holes through it. Hardware store strip of brass or steel, a drill press with a good set of drills. A little router jig for the body. Easy.
- Stereordinary
For some reason they’ve never advertised them. I always had to call orders in over the phone to get them.scheissami wrote: ↑Fri May 20, 2022 4:55 pmI can’t find them on their website… Maybe I’m just being obtuse?
- bodhi
Schaller has a similar part, though it's probably mostly just more expensive than the links provided above... Though any Schaller part I've ever come across is machined really well:
https://schaller.info/en/replacement-ki ... chor-plate
- dren68
I was considering this for a project a while back and came across these on the web.
https://graingerguitarparts.com/product ... mm-spacing
https://www.delisleguitar.com/shop/de-l ... -aluminum/
- scheissami
Thanks, all. Lots of good options to explore!
- scheissami
So, to provide some follow up for posterity:
The string plate on the pictured Kauer is indeed made by Hipshot. It’s available if you call to place an order $56/each.
I think I may go with the Schaller, as there’s not an additional flange it will be easier to flush mount. Even with shipping from Europe it works out cheaper than the Hipshot (as an aside, anyone know of any US retailers that would sell this? I couldn’t find one with my weak Google skills).
Thanks, all!
Thanks, all!
