Rehabbing my bandmate’s bass and after de-stringing two of the ferrules just fell right out.
Seems like string tension was enough to keep them in place. Should I bother trying to improve the fit? Maybe a light film of wood glue inside the holes or something?
Loose tuner ferrules
Re: Loose tuner ferrules
I just wrap some masking or painters' tape around them and press them back in.
- Sweetfinger
If it just needs a tiny bit, I'll swirl CA glue on the inside of the hole to build up just a bit of surface for the ferrule knurling to hold onto. If it needs more, I've layered paper inside the hole along with CA glue.
