MIM Player refinish
- MrJagsquire
MIM Player refinish
Continuing on from my previous upgrades including the mid boost mods I did on this one:
viewtopic.php?f=8&t=119040
I'm now stripping the paint off the body ready to refinish it in Candy Apple Red. I used a heat gun and scraper, which took about an hour today. I got a few burn marks on the wood, but it's not going to be a see through finish, so not a big issue. Turns out the body is 4 pieces, one of the joins will have to be filled as the heat gun has lifted out whatever filler they must have used (join just above the trem).
Pretty thick paint (as expected):
I've left the thimbles in for now as the paint came up clean around them, so I'll just mask them up when I spray. I will tidy up the top horn routing as I had to remove some material a while ago to fit the 3 way toggle switch and it could do with a little bit more taking out anyway as the switch catches on the side of the wood, so doesn't sit vertically and has a slight slant. I've sanded the front and edges with P180 and P320:
The back, which hasn't been sanded yet:
I wasn't going to do this just yet as I've just finished spraying a Strat I put together from a bare body, but the Jaguar slipped out of my gig bag coming in the house last week and landed on a hard floor, which took a big chunk of paint off. Figured I might as well get started on it, since the weather is good over here right now and I wanted to strip this outside.
This is the Strat I've just done:
This was grain filled, 2 coats of shellac sanding sealer, 3-4 coats of 'faded' Sonic blue (I added Olympic white to it) and 5-6 coats of Dartfords clear nitro which has minimal plastisers in it, so it will craze eventually.
I'm going to follow a similar process for this Jaguar, but will use a gold base coat under the red tinted clear, then final coats of clear on top.
- d-rock
Re: MIM Player refinish
Cool project. I'm very surprised this body doesn't have a thin veneer over the 4 piece body. I thought most modern Fenders had veneers.
- MrJagsquire
I didn't know that, so I guess it's lucky that this one doesn't. It would be hard to hide the edge of the veneer though with the shape of a Jaguar? I could understand something with binding like a Tele Custom, but it never entered my head that it might be veneered.
I got the rest of it sanded down today with P320 and filled a couple of small nicks, so I can start with shellac coats tomorrow.
- N0_Camping4U
Super cool. I've always wanted to get into refinishing. I see some folks do some fabulous work. Just feel like I'm going to screw up a good body.
- MrJagsquire
Thanks. I don't know that I do fabulous work; my last Strat spray job had a few mistakes, but I did learn a bit from it, so I hope this one will be a bit better for it.N0_Camping4U wrote: ↑Mon May 31, 2021 3:18 pmSuper cool. I've always wanted to get into refinishing. I see some folks do some fabulous work. Just feel like I'm going to screw up a good body.
I painted the first coat of shellac on it today as it's a very hot day in the UK, so it's dried nicely. Will probably due a second coat tomorrow, then I can rub down and start spraying the nitro coats later in the week.
It's darkened up quite a bit and looks quite a nice colour, so I could understand someone doing a shellac finish on an Alder body, but maybe one with fewer pieces (4) than this one:
From the back, with a few scorch marks.
- ChrisDesign
I’ve never heard of a fender having a veneer…
- d-rock
Yeah, they do it. Here's an example....
https://www.strat-talk.com/threads/tips ... at.477744/
- MrJagsquire
I guess lucky mine didn't then...
I've tried the 'bare eBay body' route with the Strat, but since I already had this one I figure an hour with the heatgun and another one sanding wasn't too bad. I did think about selling my Jaguar body as a loaded one and buy a bare Jaguar body, but since I needed the trem and some other bits it seemed better just to keep it and strip it down.
Wasn't as bad as I thought it would be to be honest and the recent experience of spraying the Strat has helped me be more prepared.
- ChrisDesign
WTF‽ Why spend extra manufacturing dollars on something no one will see? I get the vaneer with a semi-translucent burst, but not solid colours. On well.d-rock wrote: ↑Wed Jun 02, 2021 1:39 amYeah, they do it. Here's an example....
I'm unconvinced by the tonewood argument anyway, so if my MIM Jazzmaster is multiply with a veneer means nothing to me.
- kifla
MrJagsquire wrote: ↑Sun May 30, 2021 10:48 am
What a man gotta do to persuade his better half that he needs to work on guitars... again....
- MrJagsquire
It's funny, even though I'd planned to strip this down at some point I was still really annoyed with myself for what happened. I was just glad it wasn't the Strat I'd just done.
- MrJagsquire
A week after the strip down I got some coats of clear nitro on to cover the wood/shellac and put a few coats of gold on it today.
Hanging up to dry off over night:
From behind:
I sprayed it laying down, hence the screws in the back and the strap button hole:
There are a couple of small marks that I will wet sand tomorrow before giving it another coat of gold, then I can start the transparent red coats.
From behind:
- jdr1014
Looking good! Very interested to watch your progress and see final result!
- MrJagsquire
Thanks.
I got the transparent red coats on today. I knew that I needed an even coverage to avoid 'stripes', but also not such a heavy coat that I got runs. I think it's OK, but will be able to check later. It's a warm day here, so perfect weather for spraying, so I've no excuse if I mess it up.
I started on the back as that's less critical:
Then went over to the front:
4-5 coats of clear over the next few days, provided the finish looks good once it's had chance to dry off a bit. I think it's going to look nice.
- MrJagsquire
Checked it out in the sunshine this morning and spotted a couple of areas where the red coat was a bit thin and looked slightly orange, so I blended those bits in and then did a very thin coat front and back.
It really sparkles in the sunshine:
Clear coats next.
Clear coats next.
