Good replacement tuners for the Fender Vintera Jag?
- Angry Jonny
What's a reasonably priced tuner set that would fit the Vintera Series? I just pulled the trigger on an Ocean Turquoise Jag that was parted out on Ebay, but it doesn't have tuners.
- Bradley-Jazz
Re: Good replacement tuners for the Fender Vintera Jag?
Gotoh SD91s are great slotted post Kluson style tuners. Check the bushing size on your neck but I’d expect them to drop right in.
All the cheeses....
From its ocean turqoise body I assume your Vintera's parts including the neck are all from a regular Vintera (not a Modified HH). It has 0047912049 tuners (made in Taiwan).
https://www.fmicassets.com/Damroot/Orig ... 1_2019.pdf
https://darrenriley.com/store/fender-pi ... 047912049/ "(bushing) outer diameter 0.360″ (9mm)
https://shop.fender.com/en-US/parts/ele ... 12049.html
OTOH Vintera Modified has 0047912000 tuners.
https://www.fmicassets.com/Damroot/Orig ... 4_2019.pdf
https://www.ebay.com/itm/401706507631
Both are described as "KEY, VINT ST PING". Some evidence suggests they may be the same thing.
- Angry Jonny
Thanks for those links. That's actually really helpful!
