Mooncaster Project
HNB
Re: Mooncaster Project
Post by HNB » Mon May 03, 2021 9:16 pm
Right? My first time with this sort of wood dye layering. LOL
@}--Christopher--{@
Lilith Guitars
Beebe
Post by Beebe » Tue May 04, 2021 5:24 am
Looks awesome! Green is a tricky color to stain (in my experience), and you're pulling it off. It's looking better to me than the PRS.
Without music, life would be a mistake.
Beebe
Post by Beebe » Tue May 04, 2021 5:30 am
It has a little bit of that Epiphone Coronet Silver Fox look that I've always loved.
https://www.gbase.com/gear/epiphone-cor ... silver-fox
HNB
Post by HNB » Tue May 04, 2021 7:30 am
That looks beautiful!
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Wed May 05, 2021 2:29 pm
First coat of clear went on the front of back today. I am hand wiping tung oil on it. :)
ImageIMG_20210505_083158 by Christopher Louck, on Flickr
ImageIMG_20210505_083208 by Christopher Louck, on Flickr
ImageIMG_20210505_083213 by Christopher Louck, on Flickr
ImageIMG_20210505_083204 by Christopher Louck, on Flickr
ImageIMG_20210505_131927 by Christopher Louck, on Flickr
ImageIMG_20210505_131951 by Christopher Louck, on Flickr
ImageIMG_20210505_131938 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
Norrin Radd
Post by Norrin Radd » Thu May 06, 2021 4:24 am
Looking good! 8)
When you purchased the body were the bridge and tail pieces pre-drilled or did you have to do that yourself?
HNB
Post by HNB » Thu May 06, 2021 7:09 am
The bridge and tailpiece holes were drilled by warmoth, but I had to enlarge them to fit my specific bridge and stop tail thimbles. I used a scrap piece of wood to drill some different holes and test fit the thimbles in that before using the best hole size on the body with my drill press. The stock holes were too small for what I had. Once the holes were good, I used my plastic mallet to tap the thimbles in. :)
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Fri May 07, 2021 8:48 pm
The back is done. Not gloss mirror, but a nice hand rubbed tung oil glow. :D
ImageIMG_20210507_214526 by Christopher Louck, on Flickr
ImageIMG_20210507_214544 by Christopher Louck, on Flickr
ImageIMG_20210507_214540 by Christopher Louck, on Flickr
ImageIMG_20210507_214534 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Sat May 08, 2021 8:38 am
The front. Not perfect, but all hand rubbed. :)
ImageIMG_20210508_093010 by Christopher Louck, on Flickr
ImageIMG_20210508_093045 by Christopher Louck, on Flickr
ImageIMG_20210508_093052 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Sat May 08, 2021 7:30 pm
Decal applied. When clear goes on, it should blend better. :)
Image2021-05-08_08-28-18 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Mon May 10, 2021 8:35 am
Took the decal off. It just wasn't looking good with the darker background. It wasn't clearing up for whatever reason. Naked headstock it is! :D
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Wed May 12, 2021 1:19 pm
Been fighting with this project a lot. The true oil has been horrible to work with on the body. Streaky and then junk in the finish I sand or scrape out. It is driving me nuts. I think I finally have it where I am ok with it. Even the tuners didn't want to go on perfect. The angled 70's style backs didn't line up evenly so it makes the tuning pegs a little unevenly spaced. I have seen vintage and modern Fender necks worse than this, but I try to do better. LOL
ImageIMG_20210512_131521 by Christopher Louck, on Flickr
ImageIMG_20210512_131543 by Christopher Louck, on Flickr
ImageIMG_20210512_131526 by Christopher Louck, on Flickr
ImageIMG_20210512_131532 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Wed May 12, 2021 2:30 pm
Here are the tuners. Really hard to get them perfectly straight. LOL
ImageIMG_20210512_150946 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
HNB
Post by HNB » Wed May 12, 2021 5:42 pm
My mom suggested I fix the black spot in the F hole by dying the inside black, so I carefully poured dye in the neck pickup route which connects to that side and tilted it around until it was coated. Seems to have worked. Also the custom neck plate came for it. :D
ImageIMG_20210512_183416__01 by Christopher Louck, on Flickr
ImageIMG_20210512_183704 by Christopher Louck, on Flickr
@}--Christopher--{@
Lilith Guitars
Gordon
Post by Gordon » Wed May 12, 2021 6:10 pm
I never understood why f-holes were always bare... Black, bright colors, contrasting colors... I'm all for that. So that's a very welcome custom job on yours. :w00t:
