Are MIM and MIJ body's interchangeable?
Guppy
Post by Guppy » Sat Apr 03, 2021 1:12 pm
I have the opportunity to trade Jazzmaster body's with someone. He has a MIJ and I have a MIM. Will the hardware be interchangeable? I know the pickguard screw placement is slightly different. How about the tremolo? Neck?
His has a nicer colour btw. That is why I'm considering the trade.
"wants the guitar with the most sustain, plays 20 notes per second"
ohm-men
Re: Are MIM and MIJ body's interchangeable?
Post by ohm-men » Sat Apr 03, 2021 1:39 pm
There are slight differances between the MIJ/CIJ and the MIM/MIA bodies.
This has to do with the metric vs. imperial thing.
For instance the pu caveties are placed/routed slightly different, just a little but noticeble.
Neck pockets are about the same, so necks are mostly interchangeble, so make sure your neck fits the MIM body and the screw holes line up.
If you can, perhaps try to swap the pickguards as well, as it will save both parties some troubles.
For the rest, most parts should be interchangble.
Guppy
Post by Guppy » Sat Apr 03, 2021 2:18 pm
Thanks! Does the different pickup routing make a difference in pickguards or is it just the screw placement?
solfege
Post by solfege » Sat Apr 03, 2021 2:33 pm
MIJ pickguards are definitely their own thing.
CROSS_guitars
Post by CROSS_guitars » Sat Apr 03, 2021 8:04 pm
I tend to find MIJ necks are a bit wider at the heel.
CorporateDisguise
Post by CorporateDisguise » Sun Apr 04, 2021 4:19 am
Yeah, I have a MIJ Jazzmaster body and the neck pocket is definitely wider than other fenders. Both Warmoth and Musikraft necks had big gaps on it. I recently got a Japanese neck that fit perfectly. MIJ/CIJ definitely have different pickguards as well. You can convert them by drilling a few holes and widening the bridge holes.
