Gibbard Style Jazzmaster Finished Pg. 3
- HNB
Re: Gibbard Style Jazzmaster
I was wrong... LOL I wasn't counting the starting position as 1....
Christopher
Lilith Guitars
Lilith Guitars
- HNB
The switch shaft was about 1/2" too tall, but the threaded part wasn't long enough to lower it so I cut the tip shorter with my dremel. The knob went on fine, so I figure it should work.
IMG_20210316_180419 by Christopher Louck, on Flickr
IMG_20210316_180412 by Christopher Louck, on Flickr
Then I got to work wiring the switch. Since it has legs with no holes to solder wires into like pots do, I looped some single strand wire to make sure hopefully the wires stay in contact where they should. It is probably dumb and overkill, but whatever.
IMG_20210316_181401 by Christopher Louck, on Flickr
Connected it all and wired it to the volume pot.
IMG_20210316_183135 by Christopher Louck, on Flickr
Once the pickups come in and the jack, I can finish wiring it up and test it out. If the diagram I found is right, it should do: Neck, Neck and Bridge parallel, Neck and Bridge Series, and Bridge.
Christopher
Lilith Guitars
Lilith Guitars
Loving this one. The no-hole pickup covers will look cool with that.
- HosaMogami
Chris, this looks awesome. I cant wait to see the finished product! The no-hole covers on the pickups are a very cool detail to compliment your objective here. Please keep us posted!
- HNB
For sure! Thank you. I wetsanded the body. I want to wipe on one last coat before I call the body good and get to shielding it. I did get the pickups finished. Switch works great as far as I can tell.
IMG_20210318_102340 by Christopher Louck, on Flickr
IMG_20210318_102217 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
Very nice Chris!! One of the coolest you've done, and that says something!!
- HNB
- graceless
I am lusting...
- HNB
Thank you!!
Had to check out the mock up.
IMG_20210319_093302 by Christopher Louck, on Flickr
Then I worked on shielding.
IMG_20210319_094149 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- HNB
Christopher
Lilith Guitars
Lilith Guitars
- Gordon
Could be blacker...HNB wrote: ↑Sat Mar 20, 2021 4:32 pmAll set aside from the neck.
IMG_20210320_172558 by Christopher Louck, on Flickr
https://www.guitarpartsfactory.us/PK-01 ... tric-Knobs
(black jacks tend to be cheap and troublesome) (no casino pun intended)
- Gordon
Feel to AliExpress it, it's like a couple of bucks for 3 knobs: https://www.aliexpress.com/i/32915277019.html
- Gordon
And black pickguard screws.
- HNB
Not trying to black it out, just make it similar in pieces to a Gibbard Mustang.
Christopher
Lilith Guitars
Lilith Guitars
- HNB
The neck FINALLY came in! Shouldn't be long now.
IMG_20210414_133930 by Hentai No Baka, on Flickr
IMG_20210414_133917 by Hentai No Baka, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
