I'm back baby! Natural Jazzmaster Partscaster Build
HNB
Re: I'm back baby! Natural Jazzmaster Partscaster Build
Post by HNB » Wed Mar 24, 2021 12:57 pm
Beautiful work!
@}--Christopher--{@
DiMarzio Humbucker Fan Club Member
Flurko
Post by Flurko » Thu Mar 25, 2021 1:46 am
This is nice !
I don't know precisely why but the natural wood and the layout gives off a strong G&L vibe, the more techy vibe of the descendant vibrato is a nice touch with this.
Aleksandr_khru
Post by Aleksandr_khru » Thu Mar 25, 2021 5:27 am
Please measure the distance from the inside edge of the neck pocket to the centers of the bridge mounting holes. Found several drawings, everywhere these dimensions are different. I don't know where the truth is)
And how thick is this body? The information about the thickness is also different from 41 to 46mm.
I also plan to build a jazzmaster in a natural finish.
bodhi
Post by bodhi » Thu Mar 25, 2021 1:58 pm
It's 181 mm. You can find accurate templates in pdf and sometimes other formats at f.e. https://www.electricherald.com/fender-j ... templates/ . You can print subsections of these at 100% at home to check different measurements if need be.
The body thickness doesn't really matter other than that it should be thick enough that the neck screws don't crack the surface of the fretboard. Fenders are in the 41-46 range, and the only place it really matters is when you have a strat type tremolo that needs enough depth for the tremolo blocks to move without the springs touching your body.
bodhi
Post by bodhi » Thu Mar 25, 2021 2:03 pm
d-rock wrote:
Wed Mar 24, 2021 9:22 am
In the meantime, I have been looking at this thing and felt that the upper horn looked a little bare. I had ordered a inexpensive pickguard off Ebay from China for like $15 including shipping. It was for an MIJ body and this Saylor body is to US specs. I figured I'd try an experiment to see if I liked a different arrangement. I cut a hole in the upper horn for the 3-way toggle, found some white hole plugs on Amazon for the lower horn, and took the Dremel to the pickguard around the bridge posts. The pickguard and controls look more balanced and intentional to my eye, at least.
This looks sharp, I like it!
I bought a used Troy van Leuwen pickguard recently, and was surprised to find that the location of the three way toggle switch isn't where the rhythm/lead slide switch is, rather a bit closer to the neck pickup. I'll try to grab an understandable picture of it and a reference pickguard, but they're not at home at the moment, if you'd like to compare notes with the Fender design department...
d-rock
Post by d-rock » Thu Mar 25, 2021 2:19 pm
Thanks bodhi. I looked at a lot of photos of the Fano JM6 before I drilled for the new toggle switch. To me, the placement on those looks much better than the Fender JM Specials.
Aleksandr_khru
Post by Aleksandr_khru » Thu Mar 25, 2021 10:09 pm
From this site I downloaded the drawings, scaled them in the CAD, they are different.
Thanks for your measurements, I will compare with the pickguard that I have and with the drawings of the pickguards from the Internet.
UPD. I checked the drawings again, everywhere 181mm.
I was wrong. :fp:
Thanks again!
d-rock
Post by d-rock » Thu Apr 08, 2021 10:08 am
Warmoth neck came in. Beautiful work...however I really didn't like the neck carve I chose. I went for the Boatneck which they describe as a soft V. Essentially the Fatback profile with some of the shoulders shaved off. Well, to my hands it feels much more of a pronounced, sharp V. Not something I go for. My heart kind of sunk. I thought I was going to have to go the route of selling it on Ebay to try to get my money back.
I called Warmoth and they were VERY accommodating. They took the neck back, no questions asked, and said I could refund or use the full amount minus shipping towards another custom build. I decided to go that route and this time ordered a Fatback. Hopefully it'll be more of a Nocaster type U shape which is my jam. Great customer service.
So after being bummed I would have to wait 6 more weeks for the neck, I looked around for the cheapest possible solution for getting a temporary neck on this thing. I ordered a GFS Basics paddlehead for $33 and $14 tuners off Amazon. I figured I could use it until the Warmoth neck comes in and recoup the money, no problem.
The GFS neck came in like this...
So I masked it off and drew a Fender-esque shape...
After some jigsaw work and a bunch of sanding, here's the shape...
ejendres
Post by ejendres » Thu Apr 08, 2021 11:35 am
Nice work on the headstock man!
I love the color scheme you've gone for. Looks excellent
d-rock
Post by d-rock » Thu Apr 15, 2021 12:33 pm
Here's the finished product. I had on the old non-branded vibrato for the pic.
Still working on the setup and tweaking everything. I've been curious for a while now about the pickups. The demos I researched online mostly had them in Les Pauls. They sound really, really nice. They are full bodied but also have a snap or crispness to the tone. Probably due to the 25.5" scale and bolt on neck. It's probably sacrilegious to some in the offset community but I'm a big fan of the feel and response of PAF style pickups. The instrument balances so well, I've missed that since I haven't had an offset in a while.
