Intrigued!
What model is it?
The Mory! What's the plan for it? I wish my sunburst wasn't in such good shape, I'd refin in a heartbeat (to white) if it wasn't so well preserved.
I remember seeing one of these and wondering what the f**k was going on - they got pretty close to the original, much more so than a lot of copies from the mid-60s. And their pearl-tort pickguards look mental, in a good way.
That pickguard is mental, I luv it!MattK wrote: ↑Mon Oct 09, 2023 9:17 pmThat looks good, pretty convincing work there. I always love your designs, radical and retro at the same time. What's your vinegar and salt etching process?
I think you're right, the Mory pickups are slightly narrower. Bigger magnets too, and there is a wiring oddity I will try to explain one day. They sound wonderful.
The pickguard really is a jewel, I will be painting this white as a starting point I think. The gold looks quite good here but was dull and lifeless looking, I hated it every time I saw it, in the end.
epizootics wrote: ↑Mon Oct 09, 2023 9:00 pm
As always, seeing your work gets me all inspired to get busy and build something. I really like this kinda cubist(?) Esquire thing.
To confirm MattK's words about the Mory pickups, yes they are narrower. Mine came with one missing, and I decided to fit a pair of Lollar JM units. From memory the difference would be only 2-3 mm, something like that. It took some careful marking out and filing to get them to fit.
antisymmetric wrote: ↑Tue Oct 10, 2023 11:11 pmAs always, seeing your work gets me all inspired to get busy and build something. I really like this kinda cubist(?) Esquire thing.
I have actually ditched the Q-tips in favor of bigger pads made with rolled up bits of tissues, which allow you to cover more surface at once. The one thing you have to watch out for is the temperature of your pad. After a while they get hot enough to dissolve the resist, and you end up etching outside the lines. The easy solution is to just keep using new pads every thirty seconds or so.This video explains it well enough: https://www.youtube.com/watch?v=tbUilq_gWpQ
You're basically apply a resist of sorts to your piece - I usually go for nail varnish, but some people use wax or vinyl tape - that you scrape or cut wherever you want to etch. You then proceed to dab the exposed area with a Q-tip dipped in a simple solution of table salt and white vinegar connected to the (-) side of your power supply (a 12-V wall wart here), with the (+) attached to your workpiece. This time, I swapped the polarities by mistake and realized that etching with the (+) connected to the Q-tip created a layer of black oxide on the etched area. More stuff to play with
