DIY Celluloid Tortoise Knowledge Dump / Discussion
- repoman
Re: DIY Celluloid Spitfire Tortoise Knowledge Dump / Discussion
Care to share what brand of epoxy resin you use? I've made a bunch of guards similar to this over the past year but the resin I have (pro marine supplies) never dries hard enough to sand for leveling and polishing and its super viscous.
- glennleaguesny
Hey guys! I’ve been trying this, doing test pours every night for the past week just playing around to see what I can get. I started getting a couple promising pours, but I’m a bit stumped on order. In my mind, doing the yellow last makes sense. But it comes out sort of weird looking that way. I was hoping someone could point me in the order that they pour for the typical red, brown, yellow tort pattern?
My process has been, pour red. Then add some brown to the red and pour that. And then add even more brown to the red and dab that in. And then go over in yellow. The yellow seems to look not quite right and booming like the early examples you guys have. Also, is there waiting involved? After mixing I have been going straight to pouring and swirling. Are you guys waiting for the resin to cure for a little while before swirling?
Thank you!
Glenn
Thank you!
Glenn
Last edited by glennleaguesny on Thu Aug 04, 2022 5:08 am, edited 1 time in total.
- glennleaguesny
I'm still new at this, but I've been using Craft Resin Epoxy. They make smaller containers on Amazon and it's fairly cheap. It comes with the hardener. I've had no issues with it hardening up and no issues with bubbles as well.
Glennleaguesny, those all look amazing!!! That second one especially!!!!
- glennleaguesny
Thank you! They definitely aren't quite right, but it's been fun experimenting. Hoping to gather all the knowledge I can from you fine folks.Shadoweclipse13 wrote: ↑Thu Aug 04, 2022 7:52 amGlennleaguesny, those all look amazing!!! That second one especially!!!!
I think they look awesome in any case, but I guess my opinion comes from a place like this: while I may be inspired by what's been done before, I long to do something new with my builds. If you were selling tort sheets that looked like those you've already done, I would happily put something that looks like that on a project of mine I totally get that you're wanting to replicate something that's been done before, but hasn't been done the same way in a very long time though.glennleaguesny wrote: ↑Thu Aug 04, 2022 8:23 amThank you! They definitely aren't quite right, but it's been fun experimenting. Hoping to gather all the knowledge I can from you fine folks.Shadoweclipse13 wrote: ↑Thu Aug 04, 2022 7:52 amGlennleaguesny, those all look amazing!!! That second one especially!!!!
- glennleaguesny
Graduated from doing test pours to saying “fuck it” and trying on an extra mint guard I had laying around.
After watching epoxy artists and different techniques they used I decided to pour 3 different cups and mix red, dark red, and brown. From there I poured layers of each color into one big cup and poured that onto the existing pickguard (scuffed the existing guard with 600 sandpaper).
I’m overall not super happy with this first attempt. I think it looks okay, but doesn’t look super 3D. I also really wanted to add yellow but the yellow in every test pour I did made it look worse, so I opted not to add it to this guard. I actually blew the resin around with a straw once it was on the guard which added a cool effect. I’m not in love with this guard, really hoping others that have tried this method before will comment their techniques that they used. I’m a bit confused on how to the layer the resin and colors appropriately. I also noticed that the “wet” guard seemed to have some more noticeable/darker swirls. Once it dried it seemed like this became less apparent, the resin probably kept melting into each other as it dried. I wonder if waiting until the resin cures a bit before pouring might be helpful.
This is a throw-away guard so I’m going to experiment with how to clean up the bevel and screw holes. Also going to experiment with the sanding and buffing and probably try to spray some nitro amber clear on top. Stay tuned!
- DeathJag
Whoa I think that is beautiful. Dang.
- Futuron
Sick Jag anyway, those anniversary models look amazing!
- glennleaguesny
Thank you! I actually prefer the original guard on this one haha. But yeah, Fender did a great job with the 60th jag. I was so up in the air about Dakota Red or that Lake Placid Blue but over time I think I made the right color decision. At least it’s what I tell myself haha
- glennleaguesny
Keep in touch! I would happily make you a sheet for no cost at all. It would just give me more practice. Let me keep experimenting and doing test pours and when I’m comfortable that it would look semi decent I will make you one, no problem!Shadoweclipse13 wrote: ↑Thu Aug 04, 2022 11:12 amI think they look awesome in any case, but I guess my opinion comes from a place like this: while I may be inspired by what's been done before, I long to do something new with my builds. If you were selling tort sheets that looked like those you've already done, I would happily put something that looks like that on a project of mine I totally get that you're wanting to replicate something that's been done before, but hasn't been done the same way in a very long time though.glennleaguesny wrote: ↑Thu Aug 04, 2022 8:23 amThank you! They definitely aren't quite right, but it's been fun experimenting. Hoping to gather all the knowledge I can from you fine folks.Shadoweclipse13 wrote: ↑Thu Aug 04, 2022 7:52 amGlennleaguesny, those all look amazing!!! That second one especially!!!!
That would be amazing. I've always wanted a charcoal frost metallic guitar with a single-layer tort guard like Toots has done a few times, like this Uptone Wisentglennleaguesny wrote: ↑Sun Aug 07, 2022 4:25 amKeep in touch! I would happily make you a sheet for no cost at all. It would just give me more practice. Let me keep experimenting and doing test pours and when I’m comfortable that it would look semi decent I will make you one, no problem!
- glennleaguesny
Tried some new material at the suggestion of another member here. I ended up going to Michaels and buying a thick foam board and cut that into 6”x6” squares. Before that I was practicing pouring onto a pickguard material and then waiting for it to dry before prying it off, so I had a clean surface to practice on. These 6” 6” squares allow me to just throw the practice pours away and keep practicing without waiting on dry time.
I also picked up some supplies from Amazon. I was wasting a ton of wooden tools practicing swirling, dabbing, etc. I ended up picking up silicon brushes in different sizes, as well as a silicon mat to protect my desk from spills.
The pours below I’m semi happy with. I am still having a lot of trouble figuring out the right order of colors, and how to tint them the best. The amber particularly has been tough to get right. It’s also very tough to have a perfectly level table to practice on, no matter how hard I try the resin does seem to run to a side. I’m also having a lot of trouble getting the kind of “booming cloudy” look that Spitfire achieves. It’s definitely a head scratcher. I will say, a little breakthrough I’ve had through practicing has been the addition of pouring some clear resin into the colored pour. Meaning, first do your colors, and then put drops of clear on top of that. It seems to add a small 3D effect and also helps bring out the base color.
I’ve noticed some colored torts are a bit easier to get then others. The classic red and brown tort seems the easiest to dial in color wise. I’ve had pretty much no luck with a more orange centered tort. I also have had no luck achieving the big splotch look that’s on some Spitfire guards. It’s all still a headsratcher. If anyone has done this, please, please, please share any knowledge you have!
- DeathJag
You know what? I say the following:
Your tort is so unique and cool that it's not even proper tort, it's its own thing. So brand it and then people will be trying to imitate you!
Dude I freakin LOVE every experiment you've done. Nothing looks like those. And they're soooooo awesome. I super want one even though all my guitars have ended up with parchment or mint.
I'm excited to hear what you call them! Here are some ideas:
Leaky Brains
Spilled Milk
Molten River
Swirling Beauties
Zen Patterns
Leaky Brains
Spilled Milk
Molten River
Swirling Beauties
Zen Patterns
- glennleaguesny
Dude that’s so refreshing to hear! Thank you! I guess I didn’t think people would think that style was cool since it’s not something I’ve typically seen on anyone’s guitars. But maybe that’s just because no one is making stuff that looks like that. I’m still going to keep experimenting getting closer to the classic tort look, since that’s mostly what I’m into. But you’re right, maybe someone would something a bit more wild looking.DeathJag wrote: ↑Tue Aug 23, 2022 6:22 pmYou know what? I say the following:
Leaky Brains
Spilled Milk
Molten River
Swirling Beauties
Zen Patterns
I’d be happy to make you a sheet if you ever want something looking like that on your guitar!
I love the name suggestions! Especially Spilled Milk. Thank you for your input and kind words!
