- CROSS_guitars
The Height logo is cool.
I'd make the 'eight part of it slightly bigger.
- ThePearDream
I think you're right, I'll play around with the size. Thanks for the feedback!CROSS_guitars wrote: ↑Sun Apr 18, 2021 6:46 pmThe Height logo is cool.
Doug
@dpcannafax
@dpcannafax
- kifla
Wet sanding & polishing...
...and not happy with the white guard anymore.
Tort...or maybe MOTO? Will see.
- HarlowTheFish
- Deed_Poll
Some Marauder bits
The last pieces of the puzzle were the offset roller pot mounting brackets - I managed to find an excellent company nearby who laser cut steel and have full bending capabilities, so was able to send them my design and received them in good time.
Creator of the Tuffset Bridge - Locked & Ready to Rock!
www.tuffsetbridge.com ◈ @tuffsetbridge
Dude!!! Those look great Dan!! I love the custom mounting brackets!!!
- AcrylicSuperman
I'm so glad I saw this post. Been trying to come up with a solution to use a faction mustang plate but wasn't sure how I would go about mounting the springs. Never even thought about using those nuts. Does the trem work well with them? Any tricks to them?Deed_Poll wrote: ↑Thu Apr 22, 2021 10:13 amSome Marauder bits
- BTL
Some serious mad-sciencing up in here...sweet!
Owner, Lowe Custom Guitars
- Deed_Poll
On the subject of the hooks / springs, I'm not 100% sure what the effect will be - but judging by the pictures I've seen of the original Marauder II Prototype, I believe they were doing something similar to this - you can see two bolt heads in the same position as I have them here, instead of the hooks being punched and bent as they were on the Mustang and as I'm sure they would have been on the Marauder had it made full production.AcrylicSuperman wrote: ↑Fri Apr 23, 2021 12:42 pmI'm so glad I saw this post. Been trying to come up with a solution to use a faction mustang plate but wasn't sure how I would go about mounting the springs. Never even thought about using those nuts. Does the trem work well with them? Any tricks to them?Deed_Poll wrote: ↑Thu Apr 22, 2021 10:13 amSome Marauder bits
Intuitively, I feel the Dynamic Vibrato design has plenty of range up and down, so the main concern might be the angle of the arm at rest - and that can probably be solved by carefully bending the arm if required.
The more important challenge, as you say, is devising a way of holding those bolts and the ring nuts absolutely rigid and at the correct angle, and I can think of a range of solutions, like using loctite and tightening in the bolts from the front as much as possible under full string tension, or even doing the same thing with the strings off and just making sure the ring is pointing towards the string anchor post of the vibrato unit.
If those prove to be unsuccessful, I expect a little solder would certainly keep them rigid and pointing in the right direction.
I used a large diameter panhead bolt to minimise issues, and it has an Allen key adjustment so a good amount of torque is available.
Cheers!
Dan
- hillerheilman
Dan is up to his wizardry once again. Always great to seeDeed_Poll wrote: ↑Thu Apr 22, 2021 10:13 amSome Marauder bits
- AcrylicSuperman
Thanks Dan! I appreciate it!
Working on getting one of my Deed_Poll bodies finished.
I've always been more of a Fender guy, so I've never really messed with TOM/STP style bridges. I originally thought the holes were too small, but that was my fuck up in not having the correct studs for the body for mounting the bridges.
I've bought a few different ones that weren't quite right, and was wondering how far in the studs should sit in the hole before they have to be pressed in? Should they be able to go in half the length of the stud before they need to be pressed in? The ones that seem to be the best fit can only get the tip of the studs in. I'm trying to avoid having to ream or widen the holes with a drill.
- Tweedsuitcase
About to wire my lefty pots "backwards" and see if I get a useable tone control out of it. If this works, I'll see if I mind them rolling backwards, or if I want to track down reverse log pots.
Also have a stew-mac shim on the way today, so I'll pop that in place while it's apart.
I'm VERY interested to see what you find. Please let us know how things work after you put the pots in!Tweedsuitcase wrote: ↑Mon May 03, 2021 12:32 pmAbout to wire my lefty pots "backwards" and see if I get a useable tone control out of it. If this works, I'll see if I mind them rolling backwards, or if I want to track down reverse log pots.
- Tweedsuitcase
ok, so the tone knob seems to have a subtle effect through the range now - more pronounced at the very end of the range, but does roll off highs through the middle of the range.Shadoweclipse13 wrote: ↑Mon May 03, 2021 1:35 pmI'm VERY interested to see what you find. Please let us know how things work after you put the pots in!Tweedsuitcase wrote: ↑Mon May 03, 2021 12:32 pmAbout to wire my lefty pots "backwards" and see if I get a useable tone control out of it. If this works, I'll see if I mind them rolling backwards, or if I want to track down reverse log pots.
Now the volume knob rolls off pretty fast, which I'm not sure I'm a fan of.
Once i get my WD pickguard here and installed, I'll test more thoroughly.
What I'm thinking I may end up doing is, I may track down a reveres log/taper pot for the tone, and wire the existing volume back the other way.
