Strat body without usually drilled output jack
- Unicorn Warrior
Re: Strat body without usually drilled output jack
The Ed Obrien strats have side jacks too.
- FinallyBlossom
Yeah, right! But it's got these mini switchers on the regular output jack position
AND: active PUs
AND: active PUs
- FinallyBlossom
BTW: I still can't believe there's no signature model that features a different output jack position (except for the Ed O'brien model)?!?!?
Are all Strat players in love with the usual position? I mean: there are Jazzmasters/Jaguars with a Strat like output jack so why don't build a Strat with a Tele like output jack??
- Danley
I’m really not bugged either way- I could do a side jack as long as it’s not attached to some dodgy/breakable plate like most of them or a cup jack, can’t say I ever wished the standard Strat jack away though. Now that I give it some thought, it’s a pretty cool design. Beats having it direct on the pickguard where it can flex/break.
- Unicorn Warrior
The neck HB is both passive and active. Only active during the sustain modeFinallyBlossom wrote: ↑Mon Jul 01, 2019 5:42 amYeah, right! But it's got these mini switchers on the regular output jack position
AND: active PUs
- FinallyBlossom
Yeah. I'm pretty sure the Tele-like output jack solution is far more comfortable than the standard Strat position. I mean, there must be a reason why all Jackson S-style guitars and most of the Floyd Rose shred models were built with a side jack? If one would install a JM style floating tremolo on a Strat, the output jack position might be a real problem for a smooth vibrato arm actionDanley wrote: ↑Mon Jul 01, 2019 6:34 amI’m really not bugged either way- I could do a side jack as long as it’s not attached to some dodgy/breakable plate like most of them or a cup jack, can’t say I ever wished the standard Strat jack away though. Now that I give it some thought, it’s a pretty cool design. Beats having it direct on the pickguard where it can flex/break.
- Danley
One thing I don’t like about some Tele jacks is, you can’t use with certain angled cable plugs.
- FinallyBlossom
Fender used to build a Strat series where the output jack was on the pickguard itself. Unfortunately I can't find a pic of such a Strat model however the Fender Bullet is built the same way:
My idea of a Tele like output jack on a Strat is just a personal thing because I think that's the best position to avoid a conflct between the vibrato arm and your hand/picking during playing.
- Horsefeather
Side jacks get kinked up when you try to play while sitting on a couch. They can pull right out if you're standing and flailing on stage.
Strat jacks can pull out too. And they're ugly. (totally a matter of opinion, admittedly)
Face mounted jacks with 90 degree plugs don't pull out. Nor do they get in the way when you're sitting. Nor do they interfere with a vibrato bar. They can break a plastic pickguard over time but a metal plate is the easy and reliable solution.
- valley_parade
- FinallyBlossom
- Horsefeather
I guess it can't but it does require you to have a strap installed on the guitar. For a sitting-around-the-house guitar, a strap is a pain.
But for standing, yeah--that is a good viable technique, I admit.
- FinallyBlossom
BTW: strangest output jack position I ever spotted:
- Danley
Rickenbacker Eldorado:
- FinallyBlossom
