Baritone Jazzmaster Project Finished Pg. 2
- Redstar30
Re: Baritone Jazzmaster Project
I’d vote for the JB pick ups. My friend has a set in his baritone and they sound great.
I have 4 baritones at the moment. Two of them have D Sonics in the bridge position. I tune to G and I was looking for a bridge pickup with a lot of low end.
DiMarzio: D-Sonic (bridge): A lot of low end and can be a little fizzy on the top end. Requires some eq to taste and adjusting the gain on your amp. Seem to make amp gain a little more extreme. Surprisingly not muddy. Good for doom or sludgy metal.
DiMarzio Liquid Fire (bridge:): Tighter low end and mids with pretty even top end. More of a modern metal sound. Pretty articulate and unforgiving.
Seymour Duncan Phat Cats set: Really good sounding pickups and cover a lot of range/styles. Clear and not too hot. Really like the neck pick up.
Bare Knuckle Pain Killer Set ( 7 String): I have this on a ESP E-II Horizon. Tight bass response and mid focused. Great for djent tones I guess. I never been too thrilled with these pick ups.
DiMarzio D Activator Set (7 String): Mid focused, clean sounding. Kind of “meh” ihmo. No longer have them.
- HNB
Those are good suggestions. I am still on the fence. I have single coil pickups so I suppose I could try them and change them if I need to. LOL
Christopher
Lilith Guitars
Lilith Guitars
- HNB
Body came and there was much rejoicing. The poor tremolo had been drilled and plugged and redrilled at least once, but it had still been done crooked so I plugged it again, squared off the tremolo corners and marked it properly to redrill.
20240228_160750 by Christopher Louck, on Flickr
20240228_162053 by Christopher Louck, on Flickr
20240228_162413 by Christopher Louck, on Flickr
Much happier now. I also had to remove the thimbles because the ground wire wasn't installed and I like it there vs into the tremolo cavity.
20240228_165307 by Christopher Louck, on Flickr
20240228_165311 by Christopher Louck, on Flickr
The one piece ash body is super pretty!
20240228_165323 by Christopher Louck, on Flickr
20240228_165327 by Christopher Louck, on Flickr
20240228_165331 by Christopher Louck, on Flickr
I found a guard that fit it well and added pots, toggle, switch, jack, and pickups. Just need to wire it up.
20240228_165225 by Christopher Louck, on Flickr
20240228_165229 by Christopher Louck, on Flickr
20240228_165248 by Christopher Louck, on Flickr
20240228_165235 by Christopher Louck, on Flickr
20240228_165239 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
That body is really nice looking. The pickguard really doesn’t do it justice in my opinion.
- HNB
It looks better in person with the white blonde finish.marqueemoon wrote: ↑Wed Feb 28, 2024 6:14 pmThat body is really nice looking. The pickguard really doesn’t do it justice in my opinion.
Christopher
Lilith Guitars
Lilith Guitars
- Steadyriot.
I think the pickguard is rad! Sticker and all!
- HNB
Thanks! I am glad I get to use it again. I had it on a guitar before I liked. I forget why I took it off, but I am glad it lines up with the drilled holes.
Christopher
Lilith Guitars
Lilith Guitars
- HNB
Did the wiring and mounted the guard and fit the neck. I just need a better shim and the neck plate to get strings on.
20240301_143323 by Christopher Louck, on Flickr
20240301_143328 by Christopher Louck, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- s_mcsleazy
a baritone jazzmaster with an anime girl on it? never heard of such a concept
joking dude, love it.
- HNB
s_mcsleazy wrote: ↑Fri Mar 01, 2024 5:41 pma baritone jazzmaster with an anime girl on it? never heard of such a concept
Christopher
Lilith Guitars
Lilith Guitars
- HNB
Christopher
Lilith Guitars
Lilith Guitars
- HNB
All done! I really like how it sounds. The series switch is pretty awesome. It thickens it up and boosts the mids and low end. Sounds really good distorted. I got a file set off of amazon for not too much and it helped me with the lowest two strings. It is tuned in B. Since the tuners are staggered, I don't need a string tree.
20240316_134431 by Hentai No Baka, on Flickr
20240316_134444 by Hentai No Baka, on Flickr
20240316_134435 by Hentai No Baka, on Flickr
20240316_134439 by Hentai No Baka, on Flickr3
20240316_134455 by Hentai No Baka, on Flickr
20240316_134500 by Hentai No Baka, on Flickr
20240316_134506 by Hentai No Baka, on Flickr
20240316_134511 by Hentai No Baka, on Flickr
20240316_134519 by Hentai No Baka, on Flickr
Christopher
Lilith Guitars
Lilith Guitars
- dangayle
Re: Baritone Jazzmaster Project Finished Pg. 2
That is coming along nicely. I'm not typically a fan of those transparent blond finishes, but yours looks great.
