Cross Guitars - projects and restorations
Re: Cross Guitars - projects and restorations
I love most all of your projects Pat, but it really is awesome to see some lefties come out of your shop
- CROSS_guitars
Thanks. It feels weird building guitars I can't play
It would be the same for me
- repoman
CROSS_guitars wrote: ↑Sat Jul 22, 2023 10:18 pm3D printed another Rascal/scallywag bridge.
It was pretty raw steel when it arrived. I've spent a few days sanding and polishing it.
It was kinda brownish in colour but after I polished it, it came up chrome/nickel coloured.
It's still a bit pitted but looks really good now.
And here it is before I sanded and polished it.
That bridge looks awesome. Is it economically feasible or more of an experiment?
- CROSS_guitars
It's pretty expensive to have printed.
I usually only make something like this to suit a project.
- CROSS_guitars
5-way blade switch. Controversial!
- gerardguey
+1 on that bridge shape design. Especially on THAT guitar.
- CROSS_guitars
Thanks!
I'm building the neck for this right now!
- GilmourD
I've got one of those necks, too, and it's pretty damn nice!Insomnicide wrote: ↑Sat Sep 02, 2023 6:36 pmMy neck came looking much darker, more like a traditional roasted neck, so I might leave it as is. Was thinking about reshaping the headstock, so I'd be curious to find out if the neck is actually roasted or if it is just a stain.CROSS_guitars wrote: ↑Fri Sep 01, 2023 10:44 pmI haven't got around to doing anything with mine yet.Insomnicide wrote: ↑Fri Sep 01, 2023 6:39 pmHey there,
I just picked up one of the 'Roasted' MIC Jag necks.
Curious to see what you've done with yours?
Do you feel they're a sufficient quality to use in a guitar that you'd sell to someone else?
Cheers.
I would feel confident using them on a high-end build.
Although, I'm thinking of refretting them with vintage fret wire. I'd also scrape the orange stain finish off it.
IMG_20230831_174503_535 by Rosie Brennan, on Flickr
- CROSS_guitars
Wow, that does look cool. Well done.
Did you have to do much/any fret work?
- GilmourD
There was one slightly high fret, lucky number 13, and only really on the bass side, so I used my crowning file to level it out, then polished it a bit.CROSS_guitars wrote: ↑Sun Oct 08, 2023 6:15 pmWow, that does look cool. Well done.
- CROSS_guitars
Cross "Scoundrel"
Just got these amazing pics back from @Copaceticcustoms.
He finished it in Sherwood Green poly, wired and assembled it.
- ThePearDream
Hot stuff! Hard to go wrong with Sherwood Green. It shows off the body shape and bridge really well.
Doug
@dpcannafax
@dpcannafax
- MattK
Lord. Outstanding result!
- Insomnicide
Hey Gilmour, nice Jag!GilmourD wrote: ↑Sun Oct 08, 2023 4:46 pmI've got one of those necks, too, and it's pretty damn nice!Insomnicide wrote: ↑Sat Sep 02, 2023 6:36 pmMy neck came looking much darker, more like a traditional roasted neck, so I might leave it as is. Was thinking about reshaping the headstock, so I'd be curious to find out if the neck is actually roasted or if it is just a stain.CROSS_guitars wrote: ↑Fri Sep 01, 2023 10:44 pm
What tuners/ bushings did you use? I was going to put in kluson style gotohs, but the headstock is drilled out a larger diameter for modern guitar tuners. Did you use conversion bushings?
