Trem Arm Issues
- rrtxoso
Trem Arm Issues
For some reason, the trem arm is slightly too large to enter the collet. Is this user error (somehow) or what?
“Texas is a state of mind. Texas is an obsession. Above all, Texas is a nation in every sense of the word."
- Jaguar018
Re: Trem Arm Issues
Just jam the damn thing down harder. Don't wuss out.
- jacobyjd
Re: Trem Arm Issues
Assuming you have the correct arm for your trem, this is pretty much it.Jaguar018 wrote:Just jam the damn thing down harder. Don't wuss out.
- rrtxoso
Re: Trem Arm Issues
Thanks. The arm is now an inch and a half above the top, takes a great deal of force to rotate, and I cannot be removed, no matter how much force I use. I am fairly certain that this is the correct arm as it was in a bag with other paraphernalia. I was planning on playing it out tonight, which I can no longer do.
- PJazzmaster
Re: Trem Arm Issues
so is it now too close to the body? I'm sure that it can be removed, but you need to pull hard (and hold down the body, best to do this when your guitar is in the hardcase). Put some WD40 into the collet, this should help!
But: did you set up your trem spring properly? maybe it's set far too low!!!
http://www.webrocker.de/jaguar/cms/2007 ... lo-system/" onclick="window.open(this.href);return false;
- rrtxoso
Re: Trem Arm Issues
Too tall. The spring and lock are correctly set up, but the arm is stuck, like the hole and arm are mismatched sizes.
- PJazzmaster
- rrtxoso
Re: Trem Arm Issues
Seriously. I can't get it out, and have tried everything I can. I can barely rotate the arm, and I got help from my dad, used pliers, etc, with no luck. Help!!
- Jaguar018
Re: Trem Arm Issues
Loosen the strings to get rid of the tension (or just cut them all off) and then unscrew the trem plate so you can see underneath. What does it look like? Take pics.
It should look something like this:
- rrtxoso
Re: Trem Arm Issues
The arm is not poking out of the bottom, it's trapped higher up than it should be.
- Jaguar018
Re: Trem Arm Issues
I'd loosen that nut you see in the pic and see what happens.
- rrtxoso
Re: Trem Arm Issues
I tried to force it out, but couldn't manage. Austin Vintage Guitars couldn't get it with a vice and a torch. It has a new unit on there now.
- Remulak
Re: Trem Arm Issues
Had the same problem, to fix it I very gently, very slightly loosened the connector from the inside with a correctly-sized Phillips screwdriver. Now fits perfectly. It's an odd problem, I expected it to be too loose...
- whitewatersky
Re: Trem Arm Issues
Arm is stuck in my Jag. Not a big deal I spose but would like to be able to remove it... will try next string change
