Anyone tried the Bensonite bridge yet?
- RoaringTwenties
Thoughts, reviews?
- IceBlueBoogaloo
Re: Anyone tried the Bensonite bridge yet?
Crazy as it might sound to some, I’m considering selling my Staytrem to pick up one of these. Though that’s mainly because the new neck I’m swapping in is a 9.5” and my Staytrem is 7.25”. It looks like a really solid piece of kit.
It looks pretty good. I had not heard of that one.
I do prefer the offset hex adjustment for intonation on the Staytrem though, and if I buy a new offset bridge it will need to be 7.25”.
- RoaringTwenties
...the textured saddle grooves for better string grip seems like a nice feature.
- forestgreen
I got the installation video recommended on my Youtube feed a couple of weeks ago. It seems pretty well designed and priced.
- mattc
I just got mine. I was surprised how it made the tone less trebly - which is a good thing. I have a 40th Anniv JM
- lyair
Just checked this brand. Their offset bridge design looks simple and great, along with a reasonable price.
I also found that their tele saddle offers a combo of 2 brass + 1 other. Can anybody tell me about the point behind this design? Thanks.
https://www.bensoniteproducts.com/store ... ddles.html#/
- alexpigment
This is a combo that's known about in the tele world, but not exactly widely used. Brass saddles take away some of the bite compared to stainless steel. With a stainless steel E/A, you get back some of that bite so that you don't lose definition in the lower notes.lyair wrote: ↑Thu Apr 25, 2024 1:41 pmJust checked this brand. Their offset bridge design looks simple and great, along with a reasonable price.
- lyair
Thanks!alexpigment wrote: ↑Thu Apr 25, 2024 3:05 pmThis is a combo that's known about in the tele world, but not exactly widely used. Brass saddles take away some of the bite compared to stainless steel. With a stainless steel E/A, you get back some of that bite so that you don't lose definition in the lower notes.lyair wrote: ↑Thu Apr 25, 2024 1:41 pmJust checked this brand. Their offset bridge design looks simple and great, along with a reasonable price.
It seems I had some misunderstanding on brass saddles, because I've installed Gotoh In-Tune Brass Tele saddles before and found them very bright, bitey and harsh comparing to Fender stock saddles(although also brass). That's a strange experience. Maybe I'll try these Bensonite ones in future along with their offset bridge.
- alexpigment
It's an "all things being equal" situation regarding metals and their effect on tone. I suspect you went from Fender non-compensated saddles, where the string goes over a smooth curve over the saddles (which would dull the attack of the string). The Gotoh In-Tune - which I am a big fan of - are compensated and have a bit of a 'point' in the groove for intonation, and that will affect the tone. Sometimes a change in saddles means your new "sweet spot" on your tone knob is 7 rather than 10. I also like the titanium ones from Gotoh, but I've never done a comparison on the same guitar to really tell the precise tonal differences in the two.lyair wrote: ↑Thu Apr 25, 2024 5:57 pmIt seems I had some misunderstanding on brass saddles, because I've installed Gotoh In-Tune Brass Tele saddles before and found them very bright, bitey and harsh comparing to Fender stock saddles(although also brass). That's a strange experience. Maybe I'll try these Bensonite ones in future along with their offset bridge.
- lyair
alexpigment wrote: ↑Thu Apr 25, 2024 7:53 pmIt's an "all things being equal" situation regarding metals and their effect on tone. I suspect you went from Fender non-compensated saddles, where the string goes over a smooth curve over the saddles (which would dull the attack of the string). The Gotoh In-Tune - which I am a big fan of - are compensated and have a bit of a 'point' in the groove for intonation, and that will affect the tone. Sometimes a change in saddles means your new "sweet spot" on your tone knob is 7 rather than 10. I also like the titanium ones from Gotoh, but I've never done a comparison on the same guitar to really tell the precise tonal differences in the two.lyair wrote: ↑Thu Apr 25, 2024 5:57 pmIt seems I had some misunderstanding on brass saddles, because I've installed Gotoh In-Tune Brass Tele saddles before and found them very bright, bitey and harsh comparing to Fender stock saddles(although also brass). That's a strange experience. Maybe I'll try these Bensonite ones in future along with their offset bridge.
My Fender saddles are actually also compensated, but with a "slope" design. Their tonal feature might be close to non-compensated ones.
From your explanation, I think Gotoh's narrow groove design might be the reason for tonal difference.
- alexpigment
Maybe so. It’s also possible/likely that it’s just a different alloy mixture. The more yellow the brass, I believe that means more zinc and less copper. No idea what that does to the tone.
- crazyzeke
Ah I see - as much as I love the Mastery and it seemingly never needs adjustment, I always keep on eye on new(er) offset bridges to see how they compare but it sounds like this could be similar to the Halon bridge where it's taking away top-end rather than leaving it as is compared to the stock bridge, or adding a little on top.
- atomicwash
Thanks for the heads up! I had not heard of Bensonite.
- JJStrummr
I have the Bensonite bridge on a JM and a Jag build I did. Love this bridge. Stable, beautiful, easy to do intonation, and very comfortable when palm muting. I like it better than my Mastery bridge which I like but find it harder to set intonation than a 6-screw bridge like the Bensonite.
Big fan of these. And he now makes them in multiple radiuses.
