Thank you! I love the look of this. If the Zero Glide doesn't work out this looks great!Larry Mal wrote: ↑Mon Feb 13, 2023 7:48 pmA roller nut might be an option.
These are more for the slightly wider modern Fender nut widths than the narrower vintage ones, so be clear on the measurements if you go this route.
What the hell is this noise? Answer - the nut
- DeathJag
Re: What the hell is this noise?
- jorri
Aluminium varies a lot in hardness as an alloy. I had something on my bass that was a lot harder to file than brass. Gave up on it, weird accidental purchase that was advertised as brass. No, don't get that! Also, the oxide that comes of some aluminium things is horrible- ever use those aluminium picks? Grey dust everywhere. I have a brass nut and its fine, but still harder to work with than bone, it matches my guitar's general colour and the fact i have some unused switch route where i just stuck shielding tape behind. I was in fact looking for a ZeroGlide recently but usual problem of being on this island that has to now even pay import from europe.andy_tchp wrote: ↑Mon Feb 13, 2023 7:00 pmAluminium would be way too soft.
What do you/they mean by ‘Gibson style’ or ‘Fender style’?
A Tusq nut is/will be fine and is the only Graphtech product worth using IME.
But corian should also have been fine. I suppose it may get produced with different hardnesses by different companies.
Bone nut on my bass is gret now (well, I am vegetarian, but like the other guy said, if it is otherwise a waste product for the primary consumption then it doesn't bother me too much. Oh, to check everything that's in wine, bathroom products, car fluids, pharmeceuticals, and yep bone char is used in SUGAR, so its... hard to avoid that which would otherwise be put in the bin at the slaughterhouse which is driven by meat consumption.).
- DeathJag
Oh man, the maximum is .056, and I'm loving my .060 low E! I hope the zero Glide can work.DeathJag wrote: ↑Tue Feb 14, 2023 8:10 amThank you! I love the look of this. If the Zero Glide doesn't work out this looks great!Larry Mal wrote: ↑Mon Feb 13, 2023 7:48 pmA roller nut might be an option.
As I was thinking about the softness of aluminum, I had a thought about titanium! I wonder if anybody could make a titanium nut?
- andare
Re: What the hell is this noise? Answer - the nut
You want Tusq XL, not just Tusq. Permanently lubricated nuts is where it's at.
- jorri
What nut files would you use on titanium?DeathJag wrote: ↑Tue Feb 14, 2023 12:25 pmOh man, the maximum is .056, and I'm loving my .060 low E! I hope the zero Glide can work.DeathJag wrote: ↑Tue Feb 14, 2023 8:10 amThank you! I love the look of this. If the Zero Glide doesn't work out this looks great!Larry Mal wrote: ↑Mon Feb 13, 2023 7:48 pmA roller nut might be an option.
Speaking of that, the zero glide should be easy to widen because the nut isn't actually there as a nut but a retainer. The zero fret does all the work. Maybe you can find a titanium fret? (Surely stainless steel is enough?)
- DeathJag
Heh heh - titanium or steel would likely eat the strings out windings. Derrr.
That Zero Glide seems perfect. It had better work! Gonna see the shop in two weeks and I'll update the thread.
Thanks so much for the great help!
Dan
Dan
Not mine. They would be ruined fairly quickly.jorri wrote: ↑Wed Feb 15, 2023 5:29 amWhat nut files would you use on titanium?
- DeathJag
You know, the diamond ones I have just sitting around. I have so many.
Just to set the record straight - I am going to see if the Zero Glide will work. In two weeks when I see the luthier.
- tammyw
Gibson used to make a titanium zero-fret nut, I thought they were pretty neat.
- Graestang
Looks as if we're having the same life-changing experience (again?)
Græ
"the future is unwritten"
"without people you're nothing"
- Graestang
Græ
- Graestang
That is a beautiful thing. Perfectly summarised; i feel many people won't realise why these Trem's feel and sound so good. *great comprehension "timtam"timtam wrote: ↑Sun Feb 12, 2023 11:33 pmNever lubricate the string-saddle contacts on a rocking bridge (or restrict it from rocking freely). The rocking bridge relies on high string-saddle friction for the strings to grip and rock the bridge consistently back and forth with trem use, as the strings change length over the bridge. Lubrication would lower that friction, and bridge rocking can then become inconsistent, being a mix of the string gripping the bridge some of the time (good) but sliding over it at other times (bad); the bridge can never return to exactly where it started (neutral position) in that scenario. Only lubricate saddles on fixed bridges.
The noise sounds possibly trem-spring-related to me, unless maybe the strings are dragging over the back edge of the bridge plate.
Græ
- DeathJag
A custom Zero Glide nut was just ordered today. It'll be ebony wood with a stainless steel zero fret. It had to be custom because of my ridiculous string gauges haha! I am stoked for this, I think it's the best solution besides a new neck.
- DeathJag
So it is now fixed and this guitar plays like an absolute dream. No creaks. Its tone is wonderful as well, very bold and strident. Way more so than all the other Jags. It has the PV 62 pickups in it for now, but I am (still!) waiting to get the custom staggered set from creamery for it.
I took it to the guitar shop here and immediately the guy said that the nut was not cut properly, it was left too high. So he reshaped the slots and brought them down as well as level the frets. Now I have to get the headstock painted and the logo (made and) affixed and then it will actually be 100% complete!
