1965 Mustang trem arm size(s)
- NJBuck
Can anyone tell me what sizes the 1965 Fender Mustang tremolo arm are supposed to be? I need a replacement arm and the hole on my guitar measures maybe a scoonch under 5mm. Could be right at 5mm, but seems slightly under. Does anyone have any definitive knowledge about trem arm sizes for 1965 Mustangs? Thanks.
Re: 1965 Mustang trem arm size(s)
It will be an imperial measurement, not metric. I have a '64 in my drawer that I can measure accurately tomorrow with my calipers if you wantNJBuck wrote: ↑Sat Jan 08, 2022 11:56 amCan anyone tell me what sizes the 1965 Fender Mustang tremolo arm are supposed to be? I need a replacement arm and the hole on my guitar measures maybe a scoonch under 5mm. Could be right at 5mm, but seems slightly under. Does anyone have any definitive knowledge about trem arm sizes for 1965 Mustangs? Thanks.
- NJBuck
Great. Thanks.
I just dug out the '64 vibrato arm and the calipers read as:
0.19" which I believe is basically 3/16"
4.82mm in metric
4.82mm in metric
- NJBuck
Thank you. Is your trem arm for sale?
- NJBuck
So that arm would likely fit into a receptacle that is just shy of 5mm?
Yes. There’s a small grub screw that threads in against a stopper that bears against the arm.
- NJBuck
Thank you
If you're struggling to find one that will fit, I've had success buying the 5mm reissue ones and carefully filing down the part that inserts into the stopbar until it's the right size. A good engineers file and a half hour of patience getting it down to size, but still round enough, and you can fix the issue well enough - and for not a lot of dollar.
- supersonicjazzmaster
It starts... when it begins.
Ralf Kilauea
Ralf Kilauea
- NJBuck
That was the perfect way to start my Sunday morning! And, I have my answer to the tremolo issue!!! Thank you!!!
- NJBuck
Thank you!!!johnnysomersett wrote: ↑Sat Jan 08, 2022 11:46 pmIf you're struggling to find one that will fit, I've had success buying the 5mm reissue ones and carefully filing down the part that inserts into the stopbar until it's the right size. A good engineers file and a half hour of patience getting it down to size, but still round enough, and you can fix the issue well enough - and for not a lot of dollar.
Exactly.johnnysomersett wrote: ↑Sat Jan 08, 2022 11:46 pmIf you're struggling to find one that will fit, I've had success buying the 5mm reissue ones and carefully filing down the part that inserts into the stopbar until it's the right size. A good engineers file and a half hour of patience getting it down to size, but still round enough, and you can fix the issue well enough - and for not a lot of dollar.
thank you.
Professional file instruction you can find in my video.
It takes about 20-22 minutes to fit the trem arm into the unit.
Patience
Ralf Kilauea
Ralf Kilauea
- NJBuck
I sanded down the replacement arm so it will now fit in the hole in the trem tube on the guitar. How far into the tube is it supposed to go? Mine doesn't;'t reach the second hole - the hole on the bottom of the tube - is it supposed to? Thanks.
