For my Marauder build (2 Jazzmaster pickups with lipstick in the middle) I'm using the tone circuit plate to control the lipstick pickup.
The Jazzmaster pickups will be controlled with 2 vol and 1 tone pots.
I was able to find some 1 Meg Push-push pots and wondered if I could use capacitors on one of the switchable tone pot to turn it into a 50K when in "up" position for "rhythm" on both - or even just the neck JM pickups.
Any ideas?
Rhythm circuit with a push push?
- MC5tooge
Re: Rhythm circuit with a push push?
Which plate exactly? the rhythm circuit plate on the top left won't be able to use push/push pots, so I'm assuming you mean the lower main control plate. If you don't mind me asking, where did you find 1 Meg push/push pots?MC5tooge wrote: ↑Mon Dec 06, 2021 4:33 amFor my Marauder build (2 Jazzmaster pickups with lipstick in the middle) I'm using the tone circuit plate to control the lipstick pickup.
Any ideas?
- MC5tooge
Yes it's for the plate where there is normally a jack plug (except mine is having a Tele style jack and 3 pots)
I found the pots at Axesrus in England.
