I was looking to replace the stock 250k pots in my MIJ MG-69 Mustang with some Alpha 500k pots but was disappointed when they did not fit the smaller control plate. I would like to keep the control plate stock as it sits close to the pickguard. Where can I find 500k pots that will fit the MIJ control plate? Having a hard time searching the web for a direct drop in replacement. Thanks for reading!
Here are the current pots. You can see they are much smaller: https://imgur.com/a/3JfJjRZ
500K Pots for MIJ Mustang
Re: 500K Pots for MIJ Mustang
If it were me I'd drill out the holes so the better pots fit. It's a tiny difference (0.35mm) so if you ever want to return it to stock the old pots will still be fine once in, washered and tightened. You just need a 1/4" HSS bit, some masking tape and a drill and you'll be good to go all the better quality pots are 6.35mm / 1/4" shaft really and any future owner, if you're concerned with that, will be thankful for the upgrade.lawzenge wrote: βTue Nov 23, 2021 9:21 pmI was looking to replace the stock 250k pots in my MIJ MG-69 Mustang with some Alpha 500k pots but was disappointed when they did not fit the smaller control plate. I would like to keep the control plate stock as it sits close to the pickguard. Where can I find 500k pots that will fit the MIJ control plate? Having a hard time searching the web for a direct drop in replacement. Thanks for reading!
*EDIT: as per below correction, those are the pot shaft sizes, I got muddled. You need to enlarge to 3/8"
- lawzenge
It looks like that is my best option. I will look into drilling it out and get some CTS pots to install. Thanks!johnnysomersett wrote: βTue Nov 23, 2021 10:05 pmIf it were me I'd drill out the holes so the better pots fit. It's a tiny difference (0.35mm) so if you ever want to return it to stock the old pots will still be fine once in, washered and tightened. You just need a 1/4" HSS bit, some masking tape and a drill and you'll be good to go all the better quality pots are 6.35mm / 1/4" shaft really and any future owner, if you're concerned with that, will be thankful for the upgrade.lawzenge wrote: βTue Nov 23, 2021 9:21 pmI was looking to replace the stock 250k pots in my MIJ MG-69 Mustang with some Alpha 500k pots but was disappointed when they did not fit the smaller control plate. I would like to keep the control plate stock as it sits close to the pickguard. Where can I find 500k pots that will fit the MIJ control plate? Having a hard time searching the web for a direct drop in replacement. Thanks for reading!
- tammyw
You must be thinking of knobs or something. A regular full size pot has a 3/8" thread, while those Alpha mini pots are 7mm.johnnysomersett wrote: βTue Nov 23, 2021 10:05 pmIf it were me I'd drill out the holes so the better pots fit. It's a tiny difference (0.35mm) so if you ever want to return it to stock the old pots will still be fine once in, washered and tightened. You just need a 1/4" HSS bit, some masking tape and a drill and you'll be good to go all the better quality pots are 6.35mm / 1/4" shaft really and any future owner, if you're concerned with that, will be thankful for the upgrade.
Also, drilling out the control plate is not fun. That steel is not that soft, and the bit will grab trying to enlarge a hole like that.
People may say that CTS are better, but I think the Alphas are still okay, and the drop-in 500k replacement would be Alpha R-VAM500KA, iirc. They shouldn't be too hard to find.
And as for the knobs, those MIJ/CIJ's are press-on for coarse spline shafts. You can force them onto a CTS fine-splined pot without too much trouble, if you're not worried about it being perfect. Otherwise if you go with CTS pots you might want to get smooth-shafts and full size knobs, which are slightly larger.
- lawzenge
This was exactly what I was looking for. Thanks so much for the model number. I was hesitant to drill out the control plate and didn't even think about the knobs. Slightly off topic but any recommendation for what tone cap would be good for a Mustang?tammyw wrote: βWed Nov 24, 2021 7:15 pmYou must be thinking of knobs or something. A regular full size pot has a 3/8" thread, while those Alpha mini pots are 7mm.johnnysomersett wrote: βTue Nov 23, 2021 10:05 pmIf it were me I'd drill out the holes so the better pots fit. It's a tiny difference (0.35mm) so if you ever want to return it to stock the old pots will still be fine once in, washered and tightened. You just need a 1/4" HSS bit, some masking tape and a drill and you'll be good to go all the better quality pots are 6.35mm / 1/4" shaft really and any future owner, if you're concerned with that, will be thankful for the upgrade.
Ahhhhhhh, yes, had a total brain fart there. Yes, those are the knob shaft sizes sorry, it was early in the morning. Tammy is correct to correct me, knob shaft is 6.3 / 1/4", thread size is 9.5mm / 3/8" (I think, it's early again hahah)tammyw wrote: βWed Nov 24, 2021 7:15 pm
I found the MIJ steel to be pretty soft compared to others I have drilled but definitely would advise clamping it down anyway and being careful.
