Looking for such saddles:
- RaistMagus
Hi all, I'm looking to replace the Mustang saddles on my new Jazzmaster pro II. They need to:
1. Be individually height-adjustable
2. Have modern string spacing
3. Be made of metal (unlike the graphtech ones)
4. Fit the stock Mustang bridge
Does anyone know if such saddles exist?
I.e. they can be like the original JM saddles but with narrower spacing, or barrels with height screws (like the graphtech ones but metallic).
Re: Looking for such saddles:
I can't think of a bridge or saddles that satisfy all of those design criteria.
EDITED for simpler solution than my earlier version:
If the Warmoth Modified Mustang bridge came in that 52mm E-E spacing, it would cover all those criteria. So you could buy the Warmoth for the saddles and then file their edges down a little to 10.4mm string separation on the Am Pro's (52mm) bridge plate.
Or a cheaper option, although gold only, and still needing some filing ...
https://www.eyguitarmusic.com/6pcs-of-B ... _2746.html
Or file the smaller-diameter barrel saddles of the 0081239049 MIK bridge ...
https://darrenriley.com/store/fender-mu ... 081239049/
- RaistMagus
Thank you for your reply. I really like the zero sustain of the original screws and I can cure the rattle, if only the spacing was narrower...
Back to reality, I checked the bridge radius and it is 9.5" indeed, so I guess the frets must have a flatter radius. Fender never disappoints...
Before I start filing away, I will try to shim the high and low E strings with pieces cut from a feeler gauge. Unless there's a better idea for shimming material : )
- CorporateDisguise
You could get a vintage style Jazzmaster bridge with the threaded saddles. The string spacing is adjustable, and it functions fairly similarly to the mustang style. As long as you have a decent break angle over it, you don’t run into any of the problems associated with vintage bridges.
- alexpigment
This is the conclusion I came to as well. Although I think everyone on this forum would love to see a bridge like the OP described, it doesn't exist to my knowledge. Some of the fixed radius bridge designs are decent (AmPro, Mastery), but are a bit of compromise if your neck/frets aren't perfect. The vintage bridge allows for some wiggle room, and I've not had any issues with the strings jumping threads so far.CorporateDisguise wrote: ↑Wed Sep 15, 2021 3:31 amYou could get a vintage style Jazzmaster bridge with the threaded saddles. The string spacing is adjustable, and it functions fairly similarly to the mustang style. As long as you have a decent break angle over it, you don’t run into any of the problems associated with vintage bridges.
A Mastery isn't fixed radius.alexpigment wrote: ↑Thu Sep 16, 2021 7:28 pmThis is the conclusion I came to as well. Although I think everyone on this forum would love to see a bridge like the OP described, it doesn't exist to my knowledge. Some of the fixed radius bridge designs are decent (AmPro, Mastery), but are a bit of compromise if your neck/frets aren't perfect. The vintage bridge allows for some wiggle room, and I've not had any issues with the strings jumping threads so far.CorporateDisguise wrote: ↑Wed Sep 15, 2021 3:31 amYou could get a vintage style Jazzmaster bridge with the threaded saddles. The string spacing is adjustable, and it functions fairly similarly to the mustang style. As long as you have a decent break angle over it, you don’t run into any of the problems associated with vintage bridges.
- jorri
There is also the issue of 'gappy saddles'. Some mustang bridges like warmoth and all parts have a natural position where gaps between the saddles. That'll do nothing for buzz.
Feeler guage sounds alright. Its accurate at least. You could in fact do some math or action measurement and shim 4 of the strings pretty much exactly. May need some cyanoacrylate adhesive to prevent them slipping out though. Cyanoacrylate can eventually be undone with acetate and force if need to.
- jorri
*acetone
- ChrisDesign
- alexpigment
Agreed. I was taking the OP's requirements into consideration by omitting it, just for context.
Never noticed before that they're spec-ed at 52mm E-E. So an option if you're OK with tusq.ChrisDesign wrote: ↑Fri Sep 17, 2021 1:40 pmHave you checked out Graphtech saddles?
https://www.amazon.co.uk/PQ-8108-00-Str ... 730&sr=8-1
https://graphtech.com/products/tusq-sad ... jazzmaster
- alexpigment
I assume the OP mentioned that he wanted metal saddles rather than graphtech due to the inability for them to act as a string ground. Not inherently a problem if you can ground the trem, but in the stock configuration, you're going to loose the string ground.
They sound like shit too.
- ChrisDesign
You’re incredible! You’ve just explained why my Les Paul used to buzz like crazy: I used Graphtech saddles! I v could never work this one out. Then one day I swapped the bridge for a new one, and just realised my guitar no longer buzzes.alexpigment wrote: ↑Fri Sep 17, 2021 11:52 pmI assume the OP mentioned that he wanted metal saddles rather than graphtech due to the inability for them to act as a string ground. Not inherently a problem if you can ground the trem, but in the stock configuration, you're going to loose the string ground.
Well, i bet you can ground the vibrato somehow, making the GraphTech saddles an option. Personally, I would just get a staytrem bridge.
- jorri
I had a graphtech that buzzed like crazy, but in the sense of string buzz. Because they left gaps of over a mm between the saddles so the float about...wheee! No point bothering setting you action! Instead of stringa popping out of saddles the actual saddle flipped on its side- what total crap!ChrisDesign wrote: ↑Sat Sep 18, 2021 11:06 amYou’re incredible! You’ve just explained why my Les Paul used to buzz like crazy: I used Graphtech saddles! I v could never work this one out. Then one day I swapped the bridge for a new one, and just realised my guitar no longer buzzes.alexpigment wrote: ↑Fri Sep 17, 2021 11:52 pmI assume the OP mentioned that he wanted metal saddles rather than graphtech due to the inability for them to act as a string ground. Not inherently a problem if you can ground the trem, but in the stock configuration, you're going to loose the string ground.
