Hi does this wiring look right?
Im building a stereo marauder.. Mustang switch feeds a stereo jack.
Wiring a Stereo Marauder
- Nudger
Re: Wiring a Stereo Marauder
I tried to come up with something for Nudger, but it's not working right. He hit me up earlier, but I think this needs a more experienced eye than mine (I don't know much about stereo guitars at this point).
I designed the switch around a 3-position Mustang slide switch, so he could have one sound, the other, or both. I'd recommended that he use a stereo cable, but he said it's the same result with mono cables.
Nudger, can you post the picture of the whole wiring as it is, and what your intentions originally were? I'm not sure I have that in my PMs anymore.
- Nudger
I have next to no computer skills but I could do a hand drawn diagram..
Basically
Lower pots control treble half of the pickups.
Upper pots control bass halves.
Each pickup halve has an independent on off rocker switch.
This gives two separate circuits converging on the mustang switch..
I have wired as above diagram but only getting signal from one circuit?
I used a stereo cable and splitter feeding two mono cables going to separate amps.
Basically
- CorporateDisguise
Sorry, I’m unable to help, but just came to say that this thing is going to be really freaking cool when you get it all together. Excited to see how to comes together.
