Duo sonic push pull
AndyMansh
Duo sonic push pull
Post by AndyMansh » Fri Jul 30, 2021 12:25 am
I don’t suppose anyone has done the following set up with a Duo sonic ?
Seymour Duncan humbucker
CTS push/pull
Capacitor for the single coil
And has a photo of the wiring on the push pull do they?
ChrisDesign
Re: Duo sonic push pull
Post by ChrisDesign » Wed Aug 04, 2021 8:57 pm
Do you have HH or HS pickups?
ChrisDesign
Post by ChrisDesign » Sun Aug 08, 2021 3:08 am
CTS push/pull
Is it this guitar? https://www.fender.com/en-GB/electric-g ... 2538.html
JohnWainwright
Post by JohnWainwright » Sat Aug 28, 2021 4:44 pm
A push/pull is simply a pot with a switch mounted on it for convenience. The switch can be wired to do lots of different things. What are you wanting it to do on your guitar? (Coil-split the humbucker? Do Series/Parallel switching within the humbucker? Series/Parallel switching combined with the single? Phase Reversal? VariTone/dual tone caps? Etc?)
Also, I think you mean a resistor for the single coil (to offset the fact that you're doing a mixed Humbucker/Single setup).
Let me know what it is you want the push/pull to do, and I can cough up a diagram. Super simple.
jw
