I swapped bridge pup on my mij mustang & the selector now only works as on/off with the switch forwards. Centre & back position both no sound. Neck pickup works fine.
Wiring is exactly as the stock pickup. It sounds good, but have I done something wrong to lose the out of phase option- did I get the hot & ground wrong way round?
Oddly enough I really struggled to find a wiring diagram for the twangbanger. Not sure what black & white cables mean with SD pups.
Never could work out how to upload a photo here - I guess that would be helpful…
Twangbanger wiring help for mustang
- sal paradise
- Sweetfinger
Re: Twangbanger wiring help for mustang
Do you have shielding foil on the back of the pickguard?
One thing you'll have to do is sever the connection from the metal baseplate that goes to the black wire eyelet and run a separate wire from it to ground.
- sal paradise
Thanks- annoyingly that sounds a bit beyond my abilities but makes sense.
Reactivated my Flickr account!
- Sweetfinger
See that short wire on the bottom of the pickup that goes from the eyelet to the baseplate? Snip it close to the eyelet and extend the nub left on the baseplate with another wire that connects to any of the switch lugs that have a jumper to the casing of the switch. In your pics, the bottom right lug has the jumper to the casing. That will solve your problem.
- sal paradise
Thank you so much! I can definitely do that
- ChrisDesign
How did you get on?
