Which brand/type of bridge is this?
- dejohan
I got this on a second hand VM Jaguar.
Looks a bit like a Mustang bridge, but note the off-centre grooves and height adjustments screws.
Never seen this before.
- dejohan
- Wucan
Re: Which brand/type of bridge is this?
This is the closest one I can think of:
https://www.amazon.com/gp/product/B0793 ... merReviews
Doesn't explain the off-center grooves, though.
/e after some googling the HH Jazzmaster bridge looks similar as well but again the grooves are centered.
- Maggieo
I just spent fifteen minutes searching around and couldn't find one exactly like that.
- dejohan
Thanks guys, really appreciate the help.
It's a good bridge though. Works fine.
- jorri
Previous owner probably frankensteined some saddles built for Telecasters or something.
- BTL
Those look like 6-string Tele/Bullet saddles.
https://www.johnpageguitars.com/new-old ... s-set-of-6
https://www.allparts.com/products/bp-01 ... def7&_ss=r
Owner, Lowe Custom Guitars
Yep, tele saddles ...
So, similar to Fender's 0081239049 bridge, except with laterally offset saddle string grooves. Everything lines up correctly on a tele because the intonation screw hole positions are offset in the bridge plate (so that the strings have a clear path to the string-through-body holes), which brings the saddle grooves back in line. That's not the case on a jag/JM bridge plate, so it's an odd choice.
https://darrenriley.com/store/fender-mu ... 081239049/
- jorri
Yeh i was wondering...does it actually align? I know the screws have some give but everything must be mms off, unless there is some other modification.
- ChrisDesign
That is all that matters. Why cha he hardware when you’re happy with it?
Having said that, if the strings don’t align properly, replace the saddle with a Staytrem unit.
