Nut Slots - How Wide is Too Wide?
Veitchy
Post by Veitchy » Wed May 05, 2021 12:42 am
I'm going to get the nut slots enlarged on my CV Jazzmaster. 11-50 is my usual gauge, but I'm also tempted to try 12s this time around. Knowing that nut slots are often cut slightly wider than the string gauge, especially where trems are involved, I'm wondering if I get the nut cut for 12s first up, will the slots be too wide for the 11s if I decide to go back down?
String gauges are as follows if that's at all useful. Both are using an unwound third.
011, 015, 018, 26, 36, 50.
012, 016, 019, 028, 038, 052.
Scout
Re: Nut Slots - How Wide is Too Wide?
Post by Scout » Wed May 05, 2021 5:15 am
Nut slots are not cut to the thousandth of an inch, won’t be an issue .
Veitchy
Post by Veitchy » Wed May 05, 2021 4:30 pm
Ok, that's reassuring. I figured most of the middle strings would be fine, but I wasn't sure about the tolerances on the outside e/E especially.
Scout
Post by Scout » Thu May 06, 2021 8:06 am
A properly cut nut is only half the diameter of a wound string or thereabouts in depth , also wide enough that it won’t bind.
Mondaysoutar
Post by Mondaysoutar » Sat May 08, 2021 6:27 am
A little off topic but, I use 11-48s on my JM, would like to go to 12s but don’t like a wound G.. are there any pure nickel sets that do 12s without a wound G or would it just be matter of buying single Gs?
On topic, I spoke to a luthier about my nut slots if I go to 12s and as another poster said, it should be fine, might need to adjust the truss rod right enough.
HarlowTheFish
Post by HarlowTheFish » Sat May 08, 2021 8:58 am
I thought D'Add used to do a set, but I can't find it anymore. Stringjoy can hook you up with a plain G set of 12s for not a ton of cash, and I know Kalium, Labella, and D'Add can all do that if you're ordering a custom set.
jorri
Post by jorri » Sat May 08, 2021 1:29 pm
12-60 set, this may be only NYXL series but used to use them, plain G
Veitchy
Post by Veitchy » Sun May 09, 2021 4:26 pm
D'addario definitely made a set at some point, I had some on my Tele. GHS make the Boomer set I outlined above, though I've no idea what their nickel content is. They may make an unwound set in one of their other lines. Otherwise, Stringjoy or another custom string maker would likely be your best bet as you may be able to spec every string you want in the set.
Mondaysoutar
Post by Mondaysoutar » Mon May 10, 2021 2:46 pm
Ah cheers man, I’ll have a look into these.
jorri
Post by jorri » Tue May 11, 2021 4:44 am
For reference when i changed from 100 strings on my bass VI to ~70 for baritone tuning i didnt have a single issue or rattle. Depends on the nut but changing to the next guage probably not, unless you go large and the string wont fit.
Veitchy
Post by Veitchy » Tue May 11, 2021 5:56 pm
Good data. Cheers.
Arc
Post by Arc » Wed May 12, 2021 1:00 pm
Daddario XL148 12-16-20-36-48-60 but they are nickel plated steel and I really don’t like them, and Thomastik-Infeld jazz bebop 12-16-20-27-37-50, pure nickel, double wrap of thin nickel wire, balanced tension, very smooth and warm tone. I have them on a les Paul scale guitar, but they’re pricey, 20€ in Europe, 30+$ in the US. They last forever though.
Mondaysoutar
Post by Mondaysoutar » Thu May 13, 2021 4:12 pm
Ah great man. Ordered a set of the Infeld bebop 12-50, I’d always assumed they had a wound G. I’ve used pure nickel D’Addario 11-49 for ages man, fancy a wee change. Not too bad price wise for me in Scotland, 16 sheets off Amazon.
Cheers man, good tip
Arc
Post by Arc » Thu May 13, 2021 9:18 pm
Yeah more or less same price in Italy. They are great strings in my opinion. The double wrap of thin wire makes them soft to the touch, the round core is thinner as a consequence and being wrapped in nickel they do not push the pickups too hard. The tension is almost perfectly even across the set, therefore you could feel like the top strings being stiff, but you’ll soon find that employing the same kind of strength for every string is rewarding in terms of technique improvement. I dig the brass plating on the GBE strings too. And they last for ages really.
Colnago
Post by Colnago » Mon May 17, 2021 2:56 pm
Not sure what you mean. My nut files are measured as such.
Whenever I go up a size I always try with the existing slots and they nearly always need to be adjusted wider.
I’ve not tried going back down a size though, so I don’t know if the OP would have issues doing so or not.
Curious to know how nut slots are cut if they’re not cut to the thousandth of an inch.
