Staytrem posts in the thimbles of the mastery bridge?
blackgold
Post by blackgold » Mon Mar 29, 2021 5:55 pm
Hi friends ! Anyone know if the Staytrem posts fit into the thimbles of the mastery bridge? Best regards !
mbene085
Re: Staytrem posts in the thimbles of the mastery bridge?
Post by mbene085 » Mon Mar 29, 2021 6:03 pm
Mastery thimbles are just USA-spec thimbles that advertise tighter tolerances. Staytrems will fit just fine.
blackgold
Post by blackgold » Mon Mar 29, 2021 6:27 pm
And if I get some thimbles fender. What model do I have to look for? These work?
https://imgur.com/a/8nnns4I
mbene085
Post by mbene085 » Mon Mar 29, 2021 7:01 pm
Yes, those will work for a standard floating staytrem bridge.
The second question to answer is whether they fit the body you have if it's been pre-drilled - there are various metric/import sizes of outer diameter, but the Fender or Mastery ones will fit pre-drilled bodies that were dried for the standard original/USA spec thimbles.
