Intonation issues - Offset Series Mustang
jmurph
Post by jmurph » Fri Mar 12, 2021 6:09 am
I've had my Offset Series Mustang for several years now and have properly maintained it the whole time. A few months ago I noticed it was time for its routine setup. This time was different though because no matter how hard I try, I can't get the sucker to intonate properly. The only mod I've ever done was put solid graphtech saddles on it because the vintage style were slicing up my hand. I found that it actually intonated better with the solid saddles. Now I'm at a loss.
Yes, I'm using a fresh set of strings; same brand/gauge as usual.
Any suggestions would be greatly appreciated. Thanks in advance!
adamrobertt
Re: Intonation issues - Offset Series Mustang
Post by adamrobertt » Fri Mar 12, 2021 6:22 am
What exactly is the problem you're having? Usually when you can't intonate a guitar properly it's because you run out of forward or backward adjustment on individual saddles. Is that what you mean?
jmurph
Post by jmurph » Fri Mar 12, 2021 6:52 am
I can get the open string and 12th fret harmonic in tune. However, when I adjust the saddles forward & backward, it just won't pull into tune when fretting the 12th fret. I used to have no problem getting it spot on. In fact, it was one of my most reliable guitars when it came to intonation. I'm going to give it another go today and provide a more detailed explanation.
HarlowTheFish
Post by HarlowTheFish » Fri Mar 12, 2021 9:05 am
I've sometimes had strings (especially standard EB slinkies) just refuse to intonate before. Like, for no particular reason, it just will never get somewhere where it'll intonate properly. If you can spare another set, maybe see if that'll help out.
The other suggestion is to try using the neck pickup with the tone rolled off halfway when intonating. I find this works out a bit better especially on stuff like my Mustang, where the pitch warbles sharp more, because I can often get harmonics that confuse the tuner so I'll think I'm not intonated or in tune when in reality I am.
Is it too sharp or too flat? Is it a matter of you can't move the saddle far enough to intonate or of it'll be too sharp, then too flat, but never in the middle?
schoolie
Post by schoolie » Fri Mar 12, 2021 12:48 pm
If you're completely stumped, check the pickup heights. If the magnets are too close to the strings, intonation is impossible. Just one possible cause to rule out.
rockerjeff
Post by rockerjeff » Fri Mar 12, 2021 2:03 pm
Try intonating by getting the open string to be in tune with the 12th fret fretted (instead of matching the open string with the 12th fret harmonic).
adamrobertt
Post by adamrobertt » Fri Mar 12, 2021 2:06 pm
Yeah I was gonna say this. I find that using the harmonic is actually less accurate, since we aren't exactly playing harmonics all the time. Use the fretted note to intonate. You can double check with the harmonic, but I wouldn't rely on it.
ALSO, don't hit the shit out of the string - it'll make it go sharp and fluctuate. Try to hit it with the same force that you would use when picking, if not a tiny bit less.
rockerjeff
Post by rockerjeff » Fri Mar 12, 2021 2:09 pm
I've had the same problem with strings before (Dunlop).
jorri
Post by jorri » Wed Mar 17, 2021 6:49 am
There are two simple things that cause bad intonation:
-pickups so high they magnetically pull strings.
-strings should be stretched after installation, and thick ones intonate a lot better if you push infront of the bridge to ensure they are straight, i always do that with bass strings. Plain strings, cant really do all that too much.
Debaser
Post by Debaser » Mon Mar 22, 2021 3:45 pm
To be clear, the saddles were changed, THEN you had intonation issues? Or the saddles were swapped before and several subsequent string changes happened with no issues? Sounds like the latter.
If the first situation is the case, then it’s likely the saddle slots are not cut correctly thus don’t have a clean witness point.
If it’s the latter, then try another set of string, same make and model.
I’m gonna be a little presumptuous because you had no issues before, so you knew to stretch strings, and you don’t adjust your pickups after each string change. But what caused you to realize you need a whole new setup just for a string change?
There’s another option too, the graph tech substrate wore out or your nut chipped. It’s possible but only worth checking out after you try a fresh set of the same strings.
jorri
Post by jorri » Wed Mar 24, 2021 1:20 pm
As soon as saw graphtech, i thought, gaps between saddles, saddles literally move around. Also sometimes its just because the string is on the intonation screw and it needs lowering with a hugher baseplate(a bit more obvious you move intonation forward it stops contacting and contacts when moved back)
HarlowTheFish
Post by HarlowTheFish » Wed Mar 24, 2021 4:59 pm
On the standard offset bridge (one that's got stock ~56mm spacing anyway), sure, but the Offset Series has the Strat hardtail, and the Graphtech saddles for that are actually really good.
