NGD: Another squier VM Jaguar
- Arc
I decided I want a Jag for my gigs with a psychedelic/tribal project, tons of reverb and delay, cristal clean suond, vibrato and all. I went toward a squier because here you always say great thing about it, and also because I've had to spend my guitar-money for a new(second hand) car, so a squier is everything I can afford. I don't tell you how difficult it was to find it here in Italy, there was just one shop that had the 3ts at a quite steep price, but that is. I went there, tried it, and decided it was a lemon: fret buzz all over the fretboard, plus the G and high e almost completly mute after the 7th fret. And I don't like 3ts ;-) so after some research I found this very small shop that have a lot of offsets, and she is there, my olympic white Jag. The setup was perfect and the guy was really nice, he swaped the 9-42 for a set of chrome 12-52 for free!
I have since 4 days and I'm really astonished by the quality of this instrument, I even like the pickups!
The only con for me is the vibrato system, not very smooth indeed..
I hope I can take some pictures and samples soon!
Have a good weekend!
- -Anti-
Re: NGD: Another squier VM Jaguar
They can really be great guitars. I have two, and they're both excellent - even the one that's still stock.
I'd recommend shimming the neck a little, and make sure the tremolo is set up correctly. I thought one of mine was a little rough with the trem, but after a setup and neck shim it was far, far better. Hopefully that helps you as well!
www.noisemakereffects.com - Handmade, boutique grade pedals and amps starting at $46.
Etsy - http://noisemakereffects.etsy.com
Reverb - http://reverb.com/shop/noisemaker-effects
Facebook - https://www.facebook.com/noisemakereffects
- JBhome
Welcome to the club. These Squier jags are pretty amazing - definitely prefer mine to the Japanese jags I've played. Danger is, now I want a(nother) jazzmaster and mustang!
- MKR
congrats on your new jag Arc.
I would play with the trem spring tension if it doesn't feel right to you.
I have a surf green one myself, and all the finished are so nice that everytime i see one in a different colour i think that i should have chosen that one.
Let's get those pics up.
- Arc
Thanks for the reply guys! Today I've tried it with my mesa mark iic+ and it was awesome!
I agree I will have to shim the neck with the 12-52, clues in the material I should use?
In my opinion, with something like 12s you don't really need a shim, you just have to do everything else to set it up right. I had a sandpaper shim and ditched it when I got D'Addario flatwound 12s, there's a very nice amount of tension with them. Also watch for the nut, the strings might be sitting too high so it can mess with your intonation.Arc wrote:Thanks for the reply guys! Today I've tried it with my mesa mark iic+ and it was awesome!
Self improvement is masturbation. Now, self destruction...
- soggy mittens
I ♥ my VM Jag, congrats on your very excellent purchase!
- Arc
surfdivision wrote:In my opinion, with something like 12s you don't really need a shim, you just have to do everything else to set it up right. I had a sandpaper shim and ditched it when I got D'Addario flatwound 12s, there's a very nice amount of tension with them. Also watch for the nut, the strings might be sitting too high so it can mess with your intonation.Arc wrote:Thanks for the reply guys! Today I've tried it with my mesa mark iic+ and it was awesome!
Yeah strings are definitely sitting too high on the nut, what did you use to file it down? It seems made of paper :-)
I used a torch-tip cleaner. I wouldn't really reccomend it, you can also extract the nut and use a sandpaper on the bottom of it and glue it back. Check this guide ou: http://www.frets.com/FretsPages/Musicia ... ction.html" onclick="window.open(this.href);return false;Arc wrote:surfdivision wrote:In my opinion, with something like 12s you don't really need a shim, you just have to do everything else to set it up right. I had a sandpaper shim and ditched it when I got D'Addario flatwound 12s, there's a very nice amount of tension with them. Also watch for the nut, the strings might be sitting too high so it can mess with your intonation.Arc wrote:Thanks for the reply guys! Today I've tried it with my mesa mark iic+ and it was awesome!
It helped me a lot. Now the strings are sitting perfectly and intonation is almost spot-on. Also make sure that your neck pup isn't too high, since it can also affect your intonation. Honestly it took more than a year to finally set up this guitar properly (everything is stock) but every little thing was worth it.
- Arc
Thank you for the Help!!I used a torch-tip cleaner. I wouldn't really reccomend it, you can also extract the nut and use a sandpaper on the bottom of it and glue it back. Check this guide ou: http://www.frets.com/FretsPages/Musicia" onclick="window.open(this.href);return false; ... ction.html
- benji
Congrats! I am another Squier fan. I had a surf green that was fantastic. Definitely better than its Japanese counterpart. Only sold it because I got sick of the short scale.
You can go 12-52, but 11-50 work just fine on the Squier... As on most other Jags. Also, I didn't find the shim necessary after a string change and a good set up.
- Arc
I went 12-52 because I like heavy gauge anyway, on my telecaster I have 12s too, and on the Les paul i used to have 13s :-) so 12s on a Jag feel quite slinky for me, next time i'll put the thomastik 13s that have a lighter low E.benji wrote:Congrats! I am another Squier fan. I had a surf green that was fantastic. Definitely better than its Japanese counterpart. Only sold it because I got sick of the short scale.
I will try to file down a bit the nut before shimming, because as for now, with the strings sitting in the top of it, the overall action is pretty high!
- MKR
the nut on mine was lousy I had to do a ton of refiling. Also my bridge was a lemon so i got a mustang one (which is awesome by the way). and yes i felt the need to do a shim as well.
Still all those fixes were minor. My guitar itself, the tones, the fell, well it's glorious.
- PF_Flyer
- Arc
Hi everybody, I’m the OP, hope to be forgiven for this massive necrobump! Long time no see, I almost forgot I’m an offset guy, spent the last couple of years playing Gibson style guitars, but last month I picked my squier jag for fun and man! That thing still rocks! Probably the best purchase I did for the money!
Here are a couple of links from my two bands, I used the jag thru an hiwatt clone and a couple of dirt boxes. If you’d like to support by listening it would be great, given the sad time we’re living.
Youtube
https://m.youtube.com/watch?v=afrTZg0zOKw
https://m.youtube.com/watch?v=dNG3Oishzgc
Bandcamp
https://nogaar.bandcamp.com/album/ot
https://cuccuruccukuru.bandcamp.com/alb ... -zugunruhe
Two very different projects, nogaar is alt-rock, electric kuru is fully improvised psych rock. Both are basement recordings, don’t be too hard on them
Youtube
Bandcamp
