Hi OSG people !
I know the Squier VI intonation problem have been treated over and over, but I still have a problem I can't fix and I haven't found or read much about it.
Lot of people have troubles with their low E string (as I do), but my concern is with the high E string.
I can't intonate it properly, the problem is merely the same as with the low E. As a result the high E string sounds "chorussy" just like the low E string. I've compared it with a friend's Squier VI, and he does not have this problem at all. He just had the regular low E intonation problem.
Also when I play an F# on the 14th fret on the E string I've got a huge lack of sustain (not caused by a fret buzz issue).
I'm using a Circle K 98-22 gauge Bass VI strings.
Here's a recording of my Bass VI. At first I play two E on the D and B string (which sounds normal), then I play the open E and 12th fret E on the high E string (which is the problematic string), and then I play on the low E string (which have the same problem).
The second part is the same thing with distortion, it makes it much more obvious (also I play the problematic F# note).
Also, I've dampened the strings before the nut and after the bridge while recording this example, ot see if the problem came from weird sympathetic vibrations, but it's still there.
https://soundcloud.com/charlys-laborato ... us-problem
I'm sorry if the high E problem has already been treated, but I'd like to use this guitar in a new band where I play a lot of leads, and right now it sounds quite awful due to this issue.
I hope this is the right place to post, I can move it to "Tech/Setup" if needed.
Thanks a lot !
PS : if anyone is interested in hearing the BassVI in a prog rock environment, I've used it all other my band's last album, here's an excerpt :
https://www.youtube.com/watch?v=wnMbJl6bB4M
Founder and only member of the Colin Marston fan club.
