2013 Squier Vintage Modified Bass VI
invisible man
Re: 2013 Squier Vintage Modified Bass VI
Post by invisible man » Sun Dec 02, 2018 2:20 pm
https://imgur.com/gallery/bQv0REz
I just got this used for a good price. The bridge was already upgraded, not sure which one it is, anybody know? It was missing the trem arm which I picked up on eBay, still needs strap and case. I’ll have to look back over this epic thread to find the best case models. This morning I messed around playing fingerstyle with metal thumb and finger picks. Maybe one day I’ll get a better tort guard. I have some ideas for making some unique quasi-tort or tort-inspired guards.
https://soundcloud.com/billy-gashade
Axolotl
Post by Axolotl » Sun Dec 02, 2018 4:42 pm
Looks like the stock bridge to me.
invisible man
Post by invisible man » Mon Dec 17, 2018 11:44 pm
Maybe you are right, I thought they came with the standard offset threaded saddle bridge at first though. Maybe a switch was made, this thread is so epic it's hard to track. I ordered an SKB-44 bass case for it, but it didn't fit. The negative space between the neck horns wasn't quite right for the fitted case. I ended up using the SKB-44 case for my MIM Jazz Bass, and currently have the Bass VI in a chipboard case the Jazz Bass used to be in. I will have to look harder for a proper hard case that fits the Bass VI. Still need to get some new strings, nut, etc... but I can tell I love it.
timtam
Post by timtam » Tue Dec 18, 2018 12:09 am
Yep that's the current stock bridge ...
https://shop.fender.com/en-US/squier-el ... 00500.html
Looks like the 0081239001 as on Player Series jag/JM and others ...
https://reverb.com/au/item/752888-fende ... 0081239001
invisible man
Post by invisible man » Wed Apr 29, 2020 8:22 pm
Still want to find a Staytrem bridge and maybe trem for my VM, enjoying LaBella flats, bone nut, and neck shim.
Just found this channel with lots of Beatles outtake vids, here is a brief one of John on Bass VI:
https://youtu.be/au9xbl1bdlc
Last edited by invisible man on Thu Apr 30, 2020 12:57 pm, edited 1 time in total.
invisible man
Post by invisible man » Thu Apr 30, 2020 12:56 pm
Also, this replated vintage Bass VI mute was up on Reverb for a while, sold now. Wider than than the Jag mute, to fit original Bass VI bridge (and I assume Staytrem bridge). Pretty rare part. Would be great if these were reproduced, pending availability of wider bridges too.
https://reverb.com/item/28233080-update ... t=28233080
rhythmjones
Post by rhythmjones » Thu Apr 30, 2020 2:49 pm
Just put mint on my VM BVI
- Mitch
windmill
Post by windmill » Thu Apr 30, 2020 3:09 pm
Have you thought about white knobs and switches ?
rhythmjones
Post by rhythmjones » Thu Apr 30, 2020 8:13 pm
Ew!!!
- Mitch
invisible man
Post by invisible man » Tue Jun 15, 2021 3:16 pm
This glorious thread shall not die!
I shielded the pickup cavities, switch cavity, and knobs/jack cavity. Broke a grounding lug, replaced with better one.
Pickguardian acrylic plexi tortoise marble
Factory spec and custom
Indoor light test
Outdoor light test
I ordered this from Pickguardian, a non-standard semi-transparent acrylic plexi tort. Debating whether to mount it as is, or backing with white or copper foil tape. Tony said he often laquers the underside of these with white or cream to make the pattern stand out. I wanted to try it without first. Leaning towards the copper foil tape, or even a solid copper sheet.
CRWolf
Post by CRWolf » Thu Jul 01, 2021 4:19 am
So, what did you go with? I've got one in white I've been planning to work on. Might go full white for something way out of my norm.
Indoor light test
Outdoor light test
