Flatwound Strings or Rounds - Your Preference?
- JMFan
Wondering if you guys prefer wounds or flatwounds strung up on your reissue offsets or vintage as far as that goes. I have a reissue AV62 so that's why I ask here.
I know many of you all here play rock music on your offsets so flats are not the best on it and rounds are the preference for that style but for those of you who play surf music mostly rather than rock music do you prefer flats or rounds?
I prefer flats and I prefer Thomastiks.
- LanceLink
Re: Flatwound Strings or Rounds - Your Preference?
Pyramid Gold flats...
- jakeisjake
i had flats on my JM for a while and rounds on the jag. but i just switched and put flats on the jag and rounds on the JM. the flats mellow out the jag and i like that.
- Harrison
I had flatwounds on my mustang for a while and they felt good to the touch,tamed string noise/scratchiness, and mellowed out the sound. But I've since gone to strictly round with a wound G, which I loved about the flatwound set.
- nateispro
I know this is a really dumb question but is the difference between the two that noticeable?
- Harrison
To me, the feel is the most noticeable aspect. They tend to be stiffer, heavier feeling. Sound wise, it's similar to rolling off the tone knob and not such a dramatic change to my ears.nateispro wrote:I know this is a really dumb question but is the difference between the two that noticeable?
- nateispro
oh ok! thanks a lot! and they have less string noise then roundwounds right?Harrison wrote:To me, the feel is the most noticeable aspect. They tend to be stiffer, heavier feeling. Sound wise, it's similar to rolling off the tone knob and not such a dramatic change to my ears.nateispro wrote:I know this is a really dumb question but is the difference between the two that noticeable?
- Harrison
Yessir, in my experience much less squeal when sliding.nateispro wrote: oh ok! thanks a lot! and they have less string noise then roundwounds right?
- nateispro
I need to try some out!! my string noise comes through so much in my cleaner recordingsHarrison wrote:Yessir, in my experience much less squeal when sliding.nateispro wrote: oh ok! thanks a lot! and they have less string noise then roundwounds right?
- Murph
I play rock and I'm flats all the way lately! Don't think I'll ever go back, I like the sound and the feel better.JMFan wrote:
- nateispro
how do they feel different? (sorry for the stupid questions I've never used flatwounds before)Murph wrote:I play rock and I'm flats all the way lately! Don't think I'll ever go back, I like the sound and the feel better.JMFan wrote:
- selectomatic
Not a dumb question at all, and I'll try and answer within the limits of my own experience: it's really noticeable. As a 'surfer' who uses flats on all but one guitar, I found the flats smoothed out my playing, gave me a great, surfy 'thwack' that sounds great with all that 'verb, and of course cuts out a lot of string noise.nateispro wrote:I know this is a really dumb question but is the difference between the two that noticeable?
I know Dick Dale and plenty of other surf players use rounds, and they sound awesome, but when I've tried to switch back to them on my own guitars I just can't live with the sound; it sounds like one of those saloon pianos from the old cowboy movies. I've never used rounds on my Jag. It would be an interesting experiment, but it's plenty bright and twangy already and it seems born to use heavy flatwounds anyway. (BTW, I've been using Fender stainless .012-.052 recently and have no complaints, but I found Thomasticks lasted longer and sounded better to me.)
Edit: Oh, just saw nate's last question about feel. Well, your fingers don't scrape along the string surface with flats. They don't feel abrasive, and there's less wear and tear on your fingertips. However, flats don't bend as easily, if that's important to you. They're also supposed to have more tension than rounds. This is an asset when you're doing a lot of tremolo picking, although to me the difference in string tension was not very noticeable.
- AndyTran
I like string squeak
- Harrison
Me too, but I understand when people get annoyed by it. I use it for ambient effects/noise making.AndyTran wrote:I like string squeak
- nateispro
Which what i'm doing more or less thanks for all the info guys!Harrison wrote:Me too, but I understand when people get annoyed by it. I use it for ambient effects/noise making.AndyTran wrote:I like string squeak
