Yep! I owned 2 Sherwoods personally. I also worked at Fender so I am very aware of how low # those were lolvistavision wrote: ↑Wed Jan 06, 2021 8:25 pmThe LPB, Black, and Sherwood Green were always low # limited runs and when they sold out they were gone. The Metallic KO and Oly White are the only regular finishes of the Marr Jag since the beginning.edwardskim wrote: ↑Wed Jan 06, 2021 8:02 pmFurthermore, the Lake Placid Blue, Black, and Sherwood Green have all been discontinued. Only the Metallic KO and Olympic White are in production.
Johnny Marr Sig Jaguar
- edwardskim
Re: Johnny Marr Sig Jaguar
- shoule79
On a similar note, does anyone know of pickups that sound like the bareknuckles that aren't as low output?loungelife wrote: ↑Fri Feb 05, 2021 9:01 amHey, does anyone have a good recomendation for a jag pickup like the bareknuckes? I'd love to find a pair of the bareknuckles, but they've been hard to find.
Love the Marr, but its a pain switching between it and my JM/tele, which have similar output.
- JamesSGBrown
The answer is a transparent boost pedalshoule79 wrote: ↑Mon Feb 08, 2021 9:12 amOn a similar note, does anyone know of pickups that sound like the bareknuckles that aren't as low output?loungelife wrote: ↑Fri Feb 05, 2021 9:01 amHey, does anyone have a good recomendation for a jag pickup like the bareknuckes? I'd love to find a pair of the bareknuckles, but they've been hard to find.
- shoule79
That is the current solution. I like the sound more without a boost. First world problems.JamesSGBrown wrote: ↑Tue Feb 09, 2021 3:45 amThe answer is a transparent boost pedalshoule79 wrote: ↑Mon Feb 08, 2021 9:12 amOn a similar note, does anyone know of pickups that sound like the bareknuckles that aren't as low output?loungelife wrote: ↑Fri Feb 05, 2021 9:01 amHey, does anyone have a good recomendation for a jag pickup like the bareknuckes? I'd love to find a pair of the bareknuckles, but they've been hard to find.
- snarf
Looks like the price has gone up
EDIT: should have looked back a page somebody already mentioned it
Fender production seems slow. Mod shop is taking a lot of time on my order.
- loungelife
I noticed price increases across the board. Some examples: TVL JM is now $1499 up from 1325. Vintera 60s Jag is $1099 up from $1049. I'm also seeing a lot of these guitars are out of stock everywhere with just "reserve" buttons available. My hunch is increased demand with lower supply of raw materials due to covid. Plus I think we're seeing a devaluation of the US dollar, but that's more speculative.
- vistavision
The Marr Jaguar was essentially the same price for 8 years. It's original MAP in 2012 was $1749, and in the past several years ('17?'18?) the street price became $1799. Then this year it jumped up $300. Fender does this a lot. They'll keep something at a price for almost a decade and then have a substantial price increase. Maybe they want to have everybody bitch about it all at once instead of every year.
I'm sure some Fender dealer in '64 looked at the new Duo-Sonic II and thought, "That's not a Duo-Sonic. That's a Mustang".
- SuperDistortion
I know this response is months later, but FWIW... have done this exact thing - swapped bridge for a a Fralin +5%. Recommend it if you want more output for higher gain playing etc. It's exactly what you'd expect.Meriphew wrote: ↑Thu Nov 26, 2020 9:13 amI've been going back and forth on whether or not I want to change out the pickups on one of my Marr Jags (I have a KO & LPB). I like the stock BK pups, but sometimes I need more "oomph" to my sound. I'm planning on putting a set of Fralin 5% overwound in my KO Jag (which has already been modded with a Mastery Bridge and Spitfire tort guard). I'm keeping the LPB Marr completely stock.
Oh, and I'm not looking to use boost pedals to make up for the lower output, just to get that out of the way.
Who else here has swapped pickups?
Here's a tip though: the Marr has a different wiring scheme to a vintage Jag obviously, and neither I nor the Fralin people could work out how to make their neck pickup work in it. Not sure if it was a different grounding or phase arrangement, but it flat out would not operate with both pickups installed. The bridge pickup alone is an easy swap though.
Also, super minor issue - be aware that you can't simply swap the pickup cover of the BK bridge pup to the Fralin bridge pup to match the neck cover colour - the Fralin's cover is solidly attached to the pickup.
The original BKs do sound very good and relatively unique though - you might miss them as I did. They kind of remind me of a mid 70s Strat pickup, i.e. relatively low output but a beautiful sound. I ended up putting mine back in and now use an EQ/boost for playing with gain (> more mids, more output).
That said, if like you I had two Marr jags, I'd also swap pickups in one of them and keep one stock.
In retrospect, if I ever get a second Marr jag, I think I'll ask Bare Knuckle if they can sell me a higher output pickup set with the same wiring orientation as the Marr set. I really want to keep all that functionality, and they should know exactly what's required. JM, Fender and BK pretty much nailed it with this model.
The only thing different about any neck pickup in the Marr circuit is that the ground can't be shared between the claw and the negative side of the coil. So you need to cut the little jumper that usually joins the claw to the coil ground. And then install a separate ground just for the claw. That separation is necessary for series, because then the negative side of the neck coil is not grounded, but connected to the positive side of the bridge coil.SuperDistortion wrote: ↑Fri Feb 12, 2021 4:09 amHere's a tip though: the Marr has a different wiring scheme to a vintage Jag obviously, and neither I nor the Fralin people could work out how to make their neck pickup work in it. Not sure if it was a different grounding or phase arrangement, but it flat out would not operate with both pickups installed. The bridge pickup alone is an easy swap though.
- Meriphew
That info is extremely helpful. Thx!SuperDistortion wrote: ↑Fri Feb 12, 2021 4:09 amI know this response is months later, but FWIW... have done this exact thing - swapped bridge for a a Fralin +5%. Recommend it if you want more output for higher gain playing etc. It's exactly what you'd expect.Meriphew wrote: ↑Thu Nov 26, 2020 9:13 amI've been going back and forth on whether or not I want to change out the pickups on one of my Marr Jags (I have a KO & LPB). I like the stock BK pups, but sometimes I need more "oomph" to my sound. I'm planning on putting a set of Fralin 5% overwound in my KO Jag (which has already been modded with a Mastery Bridge and Spitfire tort guard). I'm keeping the LPB Marr completely stock.
- Meriphew
More great info! Thx!timtam wrote: ↑Fri Feb 12, 2021 5:05 amThe only thing different about any neck pickup in the Marr circuit is that the ground can't be shared between the claw and the negative side of the coil. So you need to cut the little jumper that usually joins the claw to the coil ground. And then install a separate ground just for the claw. That separation is necessary for series, because then the negative side of the neck coil is not grounded, but connected to the positive side of the bridge coil.SuperDistortion wrote: ↑Fri Feb 12, 2021 4:09 amHere's a tip though: the Marr has a different wiring scheme to a vintage Jag obviously, and neither I nor the Fralin people could work out how to make their neck pickup work in it. Not sure if it was a different grounding or phase arrangement, but it flat out would not operate with both pickups installed. The bridge pickup alone is an easy swap though.
- SuperDistortion
Seconding thanks for this - saving the info for when I get a second Marr.timtam wrote: ↑Fri Feb 12, 2021 5:05 am[The only thing different about any neck pickup in the Marr circuit is that the ground can't be shared between the claw and the negative side of the coil. So you need to cut the little jumper that usually joins the claw to the coil ground. And then install a separate ground just for the claw. That separation is necessary for series, because then the negative side of the neck coil is not grounded, but connected to the positive side of the bridge coil.
- Jahn
Found this - looks like the first matching headstock Marr I've seen!
- AztecGold
There have been across the board price increases on US-made fenders both guitars and amps, I believe. Some of them had been the same price for numerous years so I suppose it makes sense.
- Unicorn Warrior
Guys, guitars are getting more expensive. Doesn’t make sense. I can’t imagine the new guitar market surviving much longer like this amidst the amount of great secondhand instruments floating around.
To me, the Mexican made fenders over a grand are obsolete. There’s used ones much cheaper, the Asian ones rival the quality, and the American ones that can be had cheaper or the same price new. Absolutely no reason to buy a New Mexican fender. Especially with the disgusting looking fretboards.
