So I’ve seen enough posts and photos now to know that something is off with the rhythm circuit cavity in the Vintera jazzmasters. Replacement pick guards that “fit” still let a bit of the cavity peak out from underneath. I’ve had two aftermarket pick guards myself with this condition. The decoboom one is way better/bigger than the cheap Amazon one from musiclily but still doesn’t fully cover. I haven’t tried official fender yet because I can’t seem to find one in parchment.
But is there really that much of a difference in the size of the cavity or is it actually an aftermarket pick guard issue?
Has anyone found a replacement pick guard that 100% covers the upper cavity of the Vintera Jazzmaster?
This is my first post btw, as I work on upgrading my first offset. Been getting tons of great info from this community the whole time. Much appreciated!
Vintera JM replacement pick guard that fully covers the upper cavity?
- dylanthomaspals
- GreenKnee
Re: Vintera JM replacement pick guard that fully covers the upper cavity?
Does the stock pickguard leave a gap too? If not, I'd take that or send it off to someone who cuts custom guards. My custom Jag gaurd in parchment cost £30
- dylanthomaspals
That’s a pretty good idea. I don’t remember seeing the gap there. It’s really so minuscule it wouldn’t take much more to cover it. I’ll have to have a look for something like that.
- SpookyReverb
I don't know if they are routed differently, but I used Stratosphere to get the pickguard for my Vintera Mod and it fit:
I did have to remove some of the guard for the bridge to fit, but that wouldn't be a problem for the '60s Vintera.
- linkeroever
How did you make room for the bridge? I mean, what kind of material did you use?
- Downsman
I don't know where you're based, but I ordered this one in the UK and it fit perfectly:
https://www.ebay.co.uk/itm/114739744685
- mrventures
Did you end up finding a pickguard that fit properly?dylanthomaspals wrote: ↑Thu Feb 24, 2022 6:47 am
