'65 AV Jazzmaster with mysterious Chinese Lion.
- Fiddy
Re: '65 AV Jazzmaster with mysterious Chinese Lion.
This is a Lion's Club signature model.
- Fiddy
I'd say it's a refin too. Sounds like you want it to be something it might not be.jfromel wrote: ↑Tue Apr 20, 2021 4:48 pm
It's straight up Oly White thin skin nitro (if this is a re-fin the person who did it should consider doing Van Gogh forgeries) The matching HS is original, I got this from Fender earlier today based on the S/N... scroll to the bottom of the spec sheet - Oly White - matching HS.
- jfromel
I don't want it to be anything other than what it is, but I do want to know what it is. If it's a refin (which I doubt based on my experience and observations) that's cool but why would someone go through all the effort to strip all the paint, carve the image, fill the image then just cover it back up to the point it's almost invisible with a factory quality refin? Andy is wrong that the matching HS is not original and the only comment supporting a refin so far is the colour balance looks off, and it does because I changed the contrast on the pic. But if the answer was clear it wouldn't be a mystery:)tribi9 wrote: ↑Tue Apr 20, 2021 4:51 pmI'd say it's a refin too. Sounds like you want it to be something it might not be.jfromel wrote: ↑Tue Apr 20, 2021 4:48 pm
- Fiddy
Well, Fender wouldn't have released it with a graphite lion etched on the back and if they had, they would have mentioned it on the reply you got.
Doing a good factory refin is not that difficult unless you are MJT.
OK. I'll happily stand corrected on the matching headstock aspect.
As for the rest of it, how could I (or anyone else) have possibly known you'd altered the images in such a way?
People do stupid shit all the time. Poor decision making, drugs, alcohol, questionable modifications to musical instruments.
At least whoever repaired it did a decent job.
The custom carving would've hugely devalued the guitar had it been left as it was when being put up for sale. Like, halved the value.
Harsh... but true
- sunburster
Pretty weird if someone at Fender put that etching on the back of the guitar, but everything else checks out. Matching headstock is correct, bright white Olympic White finish is correct, neck pocket looks good, etc.
- jfromel
I did the rubbing of the graphite to expose the image AFTER I BOUGHT IT. I tried first with tracing paper and a #6 graphite bar and #2 and got nothing, I took the #2 directly to the guitar and the image was there! I finished it up with #6 and some erasing around the edge. 1 squirt of guitar polish and the Lion would go back into hiding. Looking back I think I could have gotten the image with some method similar to lifting finger prints, I still might try something like that and put the lion back in it's cage, right now I have to wear a black shirt when I play it, which is fine because most of my shirts are black.
I think it would have been possible to emboss the image after the guitar was finished but the depth of the image is so shallow and so perfect across the image that would take a CNC with a burring tool (smooth round ball) and the rotor off at slow speed, or possibly a large press with precision pressure to put in the image and have the finish intact. But that takes tools you cant just pick up at Home Depot and I haven't seen any You Tubers doing such things with their Shapeoko CNC and I have seen a lot of them because I love my Shapeoko. I don't know how many refin people have a precision industrial press or CNC's in their shop (But Fender has both of those in spades!). Image depth is about .03mm. I am going to take it to a couple local guru's and get their opinion on refin. I have yet to be fooled but it may well be a Chinese clone or a refin, I'll report back after I get some other hands on it who know more than me. I figure if the body was sanded to remove an image then refinished it would not be as thick as other JM's so I measured the body thickness with digital calipers on the upper bout by the neck joint and it is exactly 41.34mm (1 5/8"), which is dead on spec for a JM. Refin or not it's still a mystery and the best JM I have owned or played and if it's a Chinese clone I have a ton of orders to place with them!
- Fiddy
I don't think its fake, but i do think the lion didn't happen at the factory... But ive been known to be wrong. So. Yeah..
Agreed, the body doesn't look fake at all.
I (still) think shrinking/sinking filler (they would not have 'sanded to remove an image' as suggested) and a paint job touch up after a remorseful owner/'artist' realised they needed to sell the thing is more plausible than someone spending hours setting up CNC toolpaths and designs on the Fender shop floor to lightly embed a 'mysterious' design in the back of what's otherwise a bog ordinary mass production guitar.
It probably would've ended up featured here had it not been repaired: "Why did you do it? Why did you do this thing to me?"
- Ceylon
Re: '65 AV Jazzmaster with mysterious Chinese Dragon.
Assuming it has the original pickguard in this image, that wear around the truss rod access cutout looks, well, poorly cut to me. It might be the image, it might be wear from someone trying to adjust it without taking the neck off, but the cut looks too, well, rugged.
EDIT: I'm not sure that would mean anything one way or the other.
Electricity still lingers
- Beebe
That's awesome! Is it possible the guitar was laid down on something that made an imprint? Like maybe a book with raised metal artwork on the cover? Or maybe a book was put in a case with it?
Without music, life would be a mistake.
- lamp
Have you put the serial number into the Fender registration website?
- jfromel
No but I called them yesterday, gave them the SN and they sent back the build spec according to my SN, their reply is posted earlier with the specs, sadly Foo Dog Lion hiding in Finish was not listed as a feature.
I did find out a bit more. The person I got it from got it used at Big Box music store in HI so I'm going to call them and see if they can help solve the mystery of how and when the lion was put on the guitar. So I'm at least the 3rd owner. Hopefully the person who traded it in at GC was the original owner. I'm not holding my breath but but maybe I'll find something out.
- bessieboporbach
It just looks like somebody rested it on something and it made an impression in the nitro?
Not sure why this is a big mystery.
- ThatGuyOverThere
But it’s a FUN mystery. I’m getting a kick out of this journey, both here and on TGP. Please do post what you find out!bessieboporbach wrote: ↑Wed Apr 21, 2021 8:20 amIt just looks like somebody rested it on something and it made an impression in the nitro?
