Mine is the same vintage and same model, and I never noticed this either. I was traveling when you posted this, and was sure you must be measuring wrong... but I got home, and pulled mine out and measured it, and my mind was blown. I've been trying to figure out why. I can only conclude that it is to make it fit in the same case as a regular six-string Strat, compensating for the larger headstock... I dunno.captdusty wrote:BTW, I'm embarrassed to admit I owned this thing for a long time before noticing it was 24.75 scale instead of 25.5. Weird for Fender, but makes sense when you consider the cumulative tension of twice the strings.
Show me your 12 strings
- FIREBOT
Re: Show me your 12 strings
- StevePirates
I'd never known that the Strat XII was 24.75 scale. Hmmm... Now I kind of want one. (I have short, stubby, trumpian fingers).
North: The direction of the sky.
- captdusty
Maybe, but I would think offsetting the greatly increased string tension would have a lot to do with it, too.FIREBOT wrote:I've been trying to figure out why. I can only conclude that it is to make it fit in the same case as a regular six-string Strat, compensating for the larger headstock... I dunno.
- FIREBOT
Maybe, but the 1960's electric XIIs had 25.5" scales, and I've never heard there was a problem in playability... And as far as the increased string tension's effect on the neck, people commonly played 12s in the 60s (which I'm sure translated to the composition of the 12 string sets), and the 80s were all about 9s and 10s.captdusty wrote:Maybe, but I would think offsetting the greatly increased string tension would have a lot to do with it, too.FIREBOT wrote:I've been trying to figure out why. I can only conclude that it is to make it fit in the same case as a regular six-string Strat, compensating for the larger headstock... I dunno.
...the Strat is pretty easy to play though...
- starflower
Run-of-the-mill 1986 360/12 with a very loud pair of Hi-gains.
Sound close to perfect for what I need it to do, but it's a proper wrestling match every time it gets used. Presently debating whether I should forego the classic charm to exchange it for something that is more user friendly.
Sound Director & Composer at Sangwha / General Manager at Moollon Guitars. https://soundcloud.com/andi-roselund
- s_mcsleazy
i never knew the scale of the xii strats. now i kinda want to try finding one to build a jaguar xii
- StevePirates
Dude. I never even considered changing a Strat XII into a Jag XII...... Dude. Whoa.
- captdusty
Remember there's still 3/4" of scale length difference to make up. You'd have to relocate the bridge by about half that length.
- cestlamort
The string spacing on the newer nuts makes it way easier to play. I've noticed that a good set up will transform it from unplayable to effortless (some hyperbole there, but you get the idea). That said, a friend has a 360-12 (1988?) and the neck feels *tiny*.starflower wrote:Run-of-the-mill 1986 360/12 with a very loud pair of Hi-gains.
- FEXII
It looks beautiful, but I had a 360/12 and I hated changing the strings, the tuners and that R tailpiece made it a half day project. Then there was the intonation, it was impossible to get it right with the stock (6 saddle) bridge. But the sound was amazing. Obviously you can tell from my username I am a big fan of the Fender Electric XII. You can change the strings on a FEXII in half an hour, the intonation is perfect, and they sound wonderful (just not like a Rick). So for my money a FEXII is the most user friendly XII out there . . . especially if you get a 65 model with the wider nut.starflower wrote:Run-of-the-mill 1986 360/12 with a very loud pair of Hi-gains.
- Surfgreen58
- starflower
Fender XII is simply divine, the above CAR being perfect!
For my 5'11" stature I have comparatively very small hands and can deal with the nut width not too much trouble, but I certainly could do better with a wider nut by far. Curiously enough the Hi-gains being so hot, coupled with the well-known issues associated with a 6-saddle bridge means more difficulty than others when dialing in everything just right when studio tracking. A capo and working around various open voicings to match given song has made it all somewhat worthwhile in the long run, but it's sure no picnic!
- Johnny Burrito
Anyone have any experience with the cheapo Cozart 12 strings out there? I read decent reviews on TDPRI.
- SignoftheDragon
Don't do it. Just save up $350ish and get a used Danelectro. You'll be much happier.
- burntumber
I'd hit that.
